Sir, We have 3 touch screen Samsung SyncMaster 710N monitors. I want drivers software which supports...
(More)
Sir, We have 3 touch screen Samsung SyncMaster 710N monitors. I want drivers software which supports on LInux OS.
I have the same, common problem with my LCD. It keeps displaying "not optimum mode"...
(More)
I have the same, common problem with my LCD. It keeps displaying "not optimum mode" message. How can I fix it? How do this trick with adding Ohms beetwen pins 5 and 6?
My Samsung SyncMaster 181T monitor has worked without any problem for 5 years suddenly started...
(More)
My Samsung SyncMaster 181T monitor has worked without any problem for 5 years suddenly started blowing the fuse at the socket. When the fuse is replaced it will work again for up to 2 or three hours before repeating the fuse blowing trick. All the leads are good and the power supply was surge protected.
when i connect the monitor to Mac computer a floating window says to change the resolution to...
(More)
when i connect the monitor to Mac computer a floating window says to change the resolution to 1084x1024 but i can not access any control panel because the screen is otherwise completely black
The monitor is probably on protection. To start unplug monitor
from power and from computer and test computer with different monitor
to find out if...
written by ginko
Don't buy and products from this company they get cheap parts from companies going out of business. They are built to break down as soon as the...
written by worthy42
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
Many people have problems determining if their monitor is bad or their video card is bad. One good way to test this is by swapping out your monitor...
written by BobbyR1234
The discoloration problem is due to the near by magnetic field appliances like speakers which are very near to monitors ... so what you have to do is...
written by dileep007
When having problems with any monitor the following are the first things you should check when troubleshooting: 1. Check to make sure the power source...
Use Vaseline petroleum jelly to fill a scratch on an LCD screen. This works because the optical density more closely matches the LCD face than air....
by wikihow
If your LCD screen has a stuck or dead pixel (a point on the screen that is always lit or always dark), it is usually due to a transistor malfunction...
by wikihow
One method to improve the display on an LCD monitor is to use a DVI connector on a DVI capable video card. This is due to the fact that LCD monitors...
by wikihow
Zkarlo.com provides discount and used laptop parts for... Read More
Zkarlo.com provides discount and used laptop parts for thousands of models. We offer Toshiba, Sony, HP, Compaq, eMachines & Gateway, Dell and more!
Choose from thousands of parts, including: LCD Screens, Motherboards, Keyboards, AC Power Supplies, Cases, Hinges, Drives, Batteries and more!
Send your laptop to us and we will diagnose the pro... Read More
Send your laptop to us and we will diagnose the problem free of charge! We repair all over the U.S.A.! Our master certified technicians will run tests to determine the problem and will call you with a quote within 48 hours! Our labor rates are low and very fair. We are proud to be an accredited Better Business Bureau Member with an A+ rating.
We fix and repair laptop motherboard no video, no pow... Read More
We fix and repair laptop motherboard no video, no power, dc jack, lcd inverter, back light, shorted ac adapter issues down to component level. Cincinnati, Hamilton 45011, West Chester 45069, Fairfield 45246 Ohio OH Laptop PC Computer repair service, Projection bulb TV LCD, Plasma, HDTV, projector repair. Projection bulb TV, LCD TV, Plasma, project
We connect to your computer over the Internet to qui... Read More
We connect to your computer over the Internet to quickly repair your PC. Call Toll Free (877) 729-0812 for a Free Quote. Professional support with certified techs to make your computer run like new again.
1500 Castro St, San Francisco, CA 94114 | 415 8266678 | Website
Castro Computer Services provides computer har... Read More
Castro Computer Services provides computer hardware and software services for small and mid sized businesses in the San Francisco Bay area. We have both in shop and onsite services to expedite job completion. Companies that need qualified on call service technicians, whether on demand or on sched...
