The charging port was lose to begin with whenever i would plug my batt. charger in it. then one day I was jiggling around to get the phone to charge pulled it out and pushed it in and one of the metal tabs is now bent up inside of the port...????
Re: The charging port was lose to begin with whenever i...
Hello
If one of the metal is bent up and your phone is not charging then you would need to replace the charging port of your phone.Before replacing the charging port you could use a desktop charger for the main time while you get your charging port replaced.
GOODLUCK
Does it have a micro USB charger/charging port? This was the universal charging adapter most manufacturers other than Apple moved to around 5 years ago. In my experience, the charging port to charger connection can become loose and prevent charging....especially if you use the tablet or phone during charging. The best method I have found to troubleshoot the issue is to try a charger that successfully charges another device and plug it into the tablet or phone. If your device still does not charge, and especially if the connection is loose, it is most likely that your charging port is damaged. Another possible issue would be the battery itself but the charger or charging port is the most likely culprit for your issue.
<span>Hello,<br /><br />there are three or more reason why your your phone won't charge;<br /><br />1. The charger might be defective.<br />2. The charging port of the phone might be defective.<br />3. The battery cell might be very weak or the battery might be defective.<br /><br />Charger<br /><br />A defective charge can cause a phone not to charge. To actually find out if your charger is defective or not, borrow a charger from a family or friend that has the type of your phone, use the borrowed charger to on your phone. If the the phone charges, then obviously, your charger is defective and need to be replaced. It is also good to test your charger on another phone to confirm the status of the charger.<br /><br />Make sure you run the above test, before buying another charger so that you don't waste your money. Sometimes, charger might be working and phone won't charge due to some other reasons that would be discussed below. So confirm first before buying another charge. Don't buy another charged based on assumptions........<br /><br />Battery<br /><br />A battery that is very flat, I mean a battery that its cell is very weak, won't charge with a phone charger. You might have to leave the battery in the phone with the charge plugged in for some minutes or hours before the battery will begin to charge and other times, it might not charge at all.<br /><br />What make batteries to be in this kind of condition is; <br /><br />1. If you use you phone to the point when it says "low battery" and you still don't charge the battery and the phone turns off by itself. This can run down a battery cell.<br />2. If you leave a battery in the phone idle for a days or months, the battery cell will become weak. Or if you leave a battery used for days or months.<br />3. If you don't use the correct/right charger for your phone, this can drain the battery instead of charging it.<br /><br />Batteries in such condition will have to be fast charged with a desktop charger. The desktop charger will be connected directly to the battery and the battery will definitely pick up within 1 hour. Thereafter, you can continue charging it with your phone charger and it will charge immediately.<br /><br />But if the battery is defective, it won't charge at all. Even if you use a desktop charger. Such batteries needs to be replaced. Also, it is good to test the phone with another battery, and charge it to confirm before buying another battery.<br /><br />Below is a picture of what a desktop charger looks like;<br /><br /><img src="walesarumi_4.jpg" /><img src="walesarumi_3.jpg" /><br /><br />Charging port<br /><br />If non of the above seems to be the reason why your phone won't charger, then it means the charging port is defective. <br /><br />Most times defective charging port confuses people. They think the charger is the reason why their phone won't charge and after using another charger on their phone they still find out that the does still does not charge.<br /><br />Once your phone doesn't charge, the first this you test is the charger and second, the battery. But if the battery and charger seems not to be the cause of the problem, then it is the charging port that is cause the problem.<br /><br />Your charging port might not be defective, maybe it loosed contact with the phone phone or it shifted from it's position. Sometimes, the way we forcefully insert our charger into the phone can make the charging port loose contact.<br /><br />At this point, you will have to disassemble your phone. But if you feel it is a task you cannot perform yourself, then take the phone to a repairman to help you out. But if you feel you can do it yourself (DIY), read further.<br /><br />Turn off the phone. Remove the battery. After that, get a phone screw driver, unscrew all the phone screws, remove the phone cover in order to gain access to the phone panel and get to the charging port. <br /><br />Check if the charging port actually loosed contact. If it didn't loose contact, then you will have to replace the charging port. <br /><br />Note that some charging port are soldered to the phone board and some are not. So if yours is not soldered, simply remove the charging port and make a replacement. But if is soldered, you will be needing a rework station. Rework station is what you will use to remove the charging port.<br /><br />Below is a picture of what the rework station looks like;<br /><br /><img src="walesarumi_5.jpg" /> <img src="walesarumi_6.jpg" /><br /><br />I hope the above makes sense to you.......<br /><br />Good luck.<br /></span>
1. is there lint or some pants pocket debris or dirt inside the charging port on the bottom of the phone? use something non metal that won't break inside, it needs to be thin enough to move around and poke around the bottom, not interfering with the chip that sticks out.
before you do that.. turn off the phone and take out the battery just in case. you don't want to short the charging port, so why risk it.
you can use a thin side wooden tooth pick (not the thick rounded ones, they won't fit), or you can use an unused plastic brush tooth pick that's available at most stores like Walgreens, CVS, Safeway, etc..
2. If nothing comes out, try using a different wall charger adapter that works for your Samsung device. Many cell phones use a 3volt charger that won't work with Samsung smartphones because Galaxy phones need a 5volt charger. The others will just trickle charge it or may not work at all. Also, the cord itself. You can't just use any micro USB charging cable. You need to use one that can push enough electricity to your device. So it has to be a Samsung smartphone compatible one. If you have ruled this out..
3. Is the wall outlet bad? Try a different wall outlet. Example: at the airport we tried all the wall outlets in the same area, none of those charged the device. We thought it could be the charging cable or the adapter that was dead. Then we went to another area in the airport and tried again. This time we were charging the phone fine. Cable and charging adapter were apparently working great.
4. If that's not it.. what happens when you try jiggling the charging cable connected to the phone.. try angling the cable head to the left or right.. does it only charge when in a specific position? it could be the charging cable or the charging port that needs fixing..
5. If that was not the case, and everything you've tried doesn't work, it could just be the charging port on the phone is bad. Bring it to your local cellular repair shop. It should cost around $35 to $50 to fix.
6. If your phone is not worth it to fix it, it might be a better idea to buy a newer model phone. If you can't afford another phone or to fix the port, why not just buy a separate battery wall charger. You can buy a cheap China version to charge your existing battery outside of the phone and then just pop the fully charged battery in when you need to use the phone. I'd recommend charging the battery when you are sleeping.
Try changing the USB cable using the same charger, most of the USB cables that comes in the box has 2 pins only, better to change it to one standard USB. If the charging still not going, try to replace the batt with another, then you'll know if it is the batt or the port. The same happened to me. Just replaced the USB cable and charging went back to normal.
There are a few things you can try (you may have done some of them already):
It may seem simple, but try plugging your charger into another outlet.
Check the charging connector on the phone. Make sure that it's free of any dirt that could be blocking the connection to the charger.
Buy another charger. If it doesn't help, return it afterward.
It could be the battery itself that's dead. You could try looking for a replacement battery, but that may be harder to return if it doesn't help. You could also try taking the battery out, and then plug in the charger... some phones (very few) will work without the battery, but this will tell you right away if it's the battery.
The charging port on the phone itself could be loose. Try jiggling it with the charger connected to it.
The charging port could be dead or there could be some other type of electrical issue with the phone (water damage, maybe, or something else).
Hello, when a phone does not charge, it means that the phone charger or the port at which the charger is inserted in the phone is faulty.
Might be due to dust or dirt. You can Clean charging port on the phone with a brush and alcohol to remove dirt.
After cleaning it,if still not charging, you can test charger with another phone to be sure if the charger is working. And if charger works with another phone,that means the charging port on the phone is faulty and will need to replaced.
Phone not charging. Hello, when a phone does not charge, it means that the phone charger or the port at which the charger is inserted in the phone is faulty.
This seems to be a common problem for the env2. If you hold your charger a certain way in the phone does it charger? Is the charger port broken or damaged?
If so the easiest workaround is to get an external battery charger and extra battery to charge the phone.
Check out the following link for information on the battery charger and other options for the env2 charge issue.
