20 Most Recent
Verizon Communications enV2 Cellular Phone Questions & Answers
My phone says the phone
If the phone is not really overheating, the problem could likely be hardware related. You would need to contact LG customer support to see what they have to say.
Given the age of this particular model (about ten years old) it wouldn't surprise me if LG is either unable to resolve the problem remotely, or requires you to send the phone in for repair.
2/3/2018 1:21:31 AM •
Verizon...
Answered
on Feb 03, 2018
Locking text messages on my EnV 2, still deletes messages
You can now lock Inbox, SMS, MMS & Email in any Nokia phone, have a look at this post <a title="http://www.ialwayscapital.com/2009/08/how-to-hide-or-lock-sms-mms-email-in.html" href="http://www.ialwayscapital.com/2009/08/how-to-hide-or-lock-sms-mms-email-in.html">http://www.ialwayscapital.com/2009/08/how-to-hide-or-lock-sms-mms-email-in.html</a>
9/29/2016 11:20:40 AM •
Verizon...
Answered
on Sep 29, 2016
Reset unlock codes
The only way to do it is do a hard reset... press volume down key + home key + power button then wait until Apple Logo appears... keep in mind this will earase everything in your phone
2/13/2015 12:49:07 AM •
Verizon...
Answered
on Feb 13, 2015
I took video of my dads funeral with my verizon
I dont know how to convert them, I haven't gotten that far with my EnV2. However, if you have the Mini SD chip, just take that down to walmart or something, and put it in that machine. It should be able to put it on a disc for you. One that will be compatible with the windows media player on your computer. That would be the only way I would know how to do it. Hope this helps. And its not creepy. Those are things that cant be replaced. Good luck.
9/18/2013 9:46:35 PM •
Verizon...
Answered
on Sep 18, 2013
Not able to play music from sd card on env2
HI,
what you need to do is put it in ur PC and if the option of open file location comes up use it, when u see what the file location is open another of the same file containing My_music, My_pics, Music, the file should be easy to open without the option by simply going to START then search and choose Removable disk E: , after having 2 open what u need to do is make sure ur music is in My_music now once done with that if there in Folers you need to take them out and have just the MP3 file in the My_music section when u have them all out of there folders simply delete the folders...keeping the MP3s of course.. now once you have nothing but every songs MP3 file in the My_music file u are set put it in your phone then it should say downloading or checking or doing somthing with the music for a minute till you can play them...and then you DONE....=) any questions my myspace is http://www.myspace.com/johnjg7000 have fun and enjoy took me 3 days to find a way for the phone to read this stuff haha...hope it works
9/6/2013 5:22:54 AM •
Verizon...
Answered
on Sep 06, 2013
My enV2 suddenly has no speaker volume
Plug in the charger, take out the battery and try to power on the phone. The phone will say needs a battery just turn it over and lightly tap on the back of the phone. Then put the battery back in and turn it on. It should work fine, if not take out the battery and try again.
8/25/2013 3:56:13 PM •
Verizon...
Answered
on Aug 25, 2013
The backlight on the exterior
LG ENV2....reset the phone to factory defaults....wont lose data, contacts, etc....worked for me...exterior backlight now shuts off
4/16/2013 2:22:29 AM •
Verizon...
Answered
on Apr 16, 2013
What does it mean when they say a cell phone is
yes, an unlocked phone means it can be used with any carrier on any network. if it's not "full flashed" that means the phone was not completely unlocked, which means the person that did it, didn't know what they were doing and whoever purchased the phone pretty much got ripped off if they were planning on using it on any network other than the original one that the phone was made to work on. i'd say buyer beware. :)
3/24/2012 9:00:04 PM •
Verizon...
Answered
on Mar 24, 2012
Master reset for verizon lg vx9100
The phone's ESN is still associated with that other person. Verizon will generally have you wait until it expires (note: this could take months). There is nothing you can do on the phone itself to clear that out. Check with Verizon to see if they may be able to help or give you more info (like how long you'll have to wait). Call from a different phone so they can run the tests to that cell phone if needed.
(800) 922-0204
2/25/2012 5:18:31 PM •
Verizon...
Answered
on Feb 25, 2012
I just got a used lg env2 and for sum reason i
Have you tried pressing "Okay" then "Clear"? I know there is two lock features on it, and one is a double button lock. If that doesn't work there could be something wrong with the front keypad. Flip the phone open and see if it lets you unlock it that way.
11/15/2011 5:06:22 PM •
Verizon...
Answered
on Nov 15, 2011
My phone will send a
It may have been that whoever you're sending the message to has blocked their cellphone to avoid charges or It It might also be that he does not have any minutes on his phone or their text bundle has expired and cannot receive messages.
10/20/2011 10:01:08 AM •
Verizon...
Answered
on Oct 20, 2011
No sound when making calls
try to volume up while your on call. if not resolve then your ear piece is broken needs to be repaired by your provider.
7/15/2011 1:33:57 AM •
Verizon...
Answered
on Jul 15, 2011
