The Cycle does not advance, I think it is right before, or at the first rinse cycle?
First check to make sure that you have cold water coming into the machine. Most of these machines only have a cold rinse. The machine will fill up during the wash cycle if you have the temperature set to either warm or hot, however If there is no cold water coming in for the rinse the timer will not advance and the cold side of your water valve is bad - replace the valve.
It sounds to me like its a water pump problem i think you will find your water pump is not working. if the washer cant drain all its water it will not advance further than that as the machine must detect that all the water has been pumped out before it will start to spin. thus protecting the agitator from snapping.
