Toshiba Satellite A105 Notebook Logo
Posted on Jun 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Pls tell me what is the functional key combination for wireless for my toshiba laptop?
Anonymous
Level 3:
  • Master 742 Answers
  • Posted on Jun 23, 2010
Anonymous
Master
Level 3:
Answers
742
Questions
0
Helped
193900
Points
2315
Look for the wifi icon on any of your keyboard's function keys (F1 to F12). The wifi icon looks like a wave or radio signal like ))) or ((( or ((())). When you find that icon, example, in F10, then just press and hold down FN and press F10. This will turn your wifi on.
Also, if your laptop have a mechanical switch, you have to turn it ON first. The mechanical or manual switch is found usually in the sides and can be turned ON or OFF by sliding sideways.
Please post feedback so that I can help you further.
How do I turn on wireless capability
To enable or disable wireless functions, you must use the Hot Key combination of "Fn" + "F8". This means to press and hold the "Fn" key (near the windows key), and the press the "F8". This is a toggling function. Each time you press the key, it will turn on or turn off the function. Look for the Wireless Light to ensure that the wireless activated.
1helpful
How do I turn on the wireless switch?
The Lenovo IdeaPad Y450-534 PC Notebook is supposed to have a wifi switch at the front right side of the laptop. If this button isn't available, then ot wil be a combination of the fn button and one of the Function keys. There is supposed to be a blue wi fi icon on the Function key. On a Toshiba it would be F8.
What is the function key to turn wireless on
How to turn on/off Wireless in various Laptop Models ------------------------------------------------------------------------------------
Vendor/Model-----------Type----------Location
Dell D600 & D610-----KeyBoard-----Fn+F2
HP nc4000 & nc4010-----Button-----Above Keyboard
HP nc4220-----Button-----Left Side of Laptop Near USB Port
HP nc6000 & nc6220-----Button-----Above Keyboard
HP nx9010-----Button-----Front side of laptop
HP Omnibook 6200-----Button-----Left side of laptop
IBM T43-----Keyboard combination-----Fn + F5-----Click "Turn On"
IBM X32-----Keyboard combination-----Fn + F5-----Click "Turn On"
Toshiba M1 & M2-----Switch-----Left side of laptop-----Towards
front
Toshiba R100-----Switch-----Right side of laptop
Toshiba TE2000-----Switch-----Left side of laptop-----By Vol ctrl
Toshiba Tecra 2100-----Switch-----Left side of laptop-----By Vol ctrl
Where to locate Bluetooth on toshiba satellite
Turn on your WiFi/Wireless/WLAN, it will also turn on your bluetooth. Laptops which have bluetooth and wireless have combined function for bluetooth and wireless. You must installed bluetooth and WLAN combined driver to use this function.
1helpful
Does TOSHIBA SATELLITE 2805-S301 have a way to go wireless
Hello If your using Microsoft Windows open, Controll Panel , System , Device Manager. Look down the list to Network Adapters and click the plus symbol. If you have a wireless card installed it will show the name and type. Right click the wireless adapter and click properties. This box will tell you the status of your wireless adapter. If no wireless adapter is shown you will have to install a card. If the card is present and enabled you may have to turn the wireless function on by using a combination of keyboard keys or look for a switch on the computer. Hope this helps.
builderdale
15helpful
2answers
I have a Toshiba Qosmio F60 series. My son using
We had the same problem and the above solution didn't work. It wasn't anything your son did, but obviously a problem with the computer itself. Disconnect from the mains and pull out the battery with the computer still going, then restart. When prompted just open Windows normally and the wifi was now functional again.
2answers
Where is the switch or function key combination to turn on wireless connection?
It's difficult to tell, but there seems to be a small switch on the front, that may activate the wireless connection. If that isn't it, you can usually access the modems through control panel, under 'network and internet,' and the wireless assistant, or possibly the network and sharing center; if the wireless modem is disabled, right clicking on the icon will usually give you an option to activate it, or you can connect to a network through the network and sharing center, as well as detecting networks, and that will tell you whether or not the thing is working.
What is the function key used to reset/turn the wireless on; the wireless light is on, but my wife's computer keeps telling her to turn on wireless capability and WLAN disabled. We use a wireless router (I...
tHE COMBINATION IS THE FUNCTION KEY AND THE F2 BUTTON TO TURN OFF AND ON THE WIRELESS. HOLD DOWN THE FUNCTION KEY WHILE PRESSING THE F2 KEY... HOPE THIS HELPS
1helpful
Wireless function key combination
Usually on the toshiba it is Fn and F2 or F4 the f key will have a coloured picture of an antenna with waves coming off of it.
Also most toshiba laptops have a physical switch on the edge of the case below the keyboard. Make sure that switch is on first then try the Fn and function key combo as they work together like a two way light switch. Both must be on for the card to be active.
Chris
Armor-IT
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
