prob i have is that i turned the tv off by the on/off button instead of remote control, when i tried to turn it back on nothing happened. i checked the fuse and took back off to make sure internal fuse was ok, which it is.i did however notice that 1 piece near the internal fuse had discoloured, could this be the fault. if so how can i fix it, thanx
Try these simple trick to find out yor remote control working or not....
Point the remote control towards the Camera of a Mobile Camera
phone,with the camera on. While pressing remote, we can see a light
(Infra Red) coming from its IR LED through the Mobile Camera if the
Remote is working. If the problem with the component that mentioned by you, write down the Number written on that and replace it with the same by the help of a Soldering Iron. Also see the writing near to it for finding out what the component is.... For eg. C=Capacitor, R=Resistor, TR or Q=Transistor, IC=Chip, D=Diode etc.
firstly check your tv switch contacta, that switch has 4 four contact
two make contacts.
if the switch is ok, then check your power supply components like
power transistor, diodes, and fusible resistors,resistor with less values,
the problem will be solved, ok
My Goodmans LD1540WD 15" LCD TV does not appear to have any means of retuning. Digital...
(More)
My Goodmans LD1540WD 15" LCD TV does not appear to have any means of retuning. Digital changeover means I have no reception. The guide does not help. What can I do to retune?
Hi, Ive just got a second hand goodmans tvc143ts for a bedroom and I cant find anything in the menu...
(More)
Hi, Ive just got a second hand goodmans tvc143ts for a bedroom and I cant find anything in the menu to tune it into the sky cable in that room. Please help
I have a Goodmans 257NS TV which is working fine, but the sound keeps cutting out periodically for...
(More)
I have a Goodmans 257NS TV which is working fine, but the sound keeps cutting out periodically for very short bursts (less than a second each time, but sometimes several times in a row). It does this both when used with the digibox and the DVD player. Can it be fixed? Thanks!
