Question about Goodmans GTVL32W27HDF 32 in. LCD TV
Goodmans LD3265D1 TV won't switch on.
TV won't switch on. Stand-by light goes off and DTV note appears very briefly, stand-by light then flashes and goes back into stand-by mode.
Posted by jks888 on
Anonymous
    New Friend:
Use a freeview box, turn the dtv off in the menu
To get it too power on press the source button a lot after a (good) few trys your get it up on another source, my own tv does this and using a freeview/freesat box makes it use-able just a pain to turn on in the first place even if you turn the dtv off in the menu
If anyone knows how to get it to turn on stright to another source would be great to know how
Posted on Dec 19, 2010
Goodmans ld3265d1 user guide
Try this link to download the user manual.
Home page Goodmans
Jan 14, 2014 | Televison & Video
When you turn the tv on the red light on the front(stand by/timer)flashes and the tv starts to come on and then it turns off.
Do you mean the screen turns on briefly or the stand by light just keeps blinking. If the tv turns off after switching on then it probably means a protection circuit fault. Also please provide me the number of times it blinks before it pauses. Awaiting your resposnse.
Regards,
Sai.
Aug 19, 2008 | Sony Televison & Video
Does anyone know the sky remote code for my goodmans GTVL19W17HDF ? please
Hello
Setup codes for Goodmans TV with Sky remote are:
065 064 100 588 285 037 292 544 207 318 363 399 402 515 527 392 371 245 563 297 584 060 103 263 508 063 616 055
527
055
402
563
662
696
652
Follow the steps below
1* Select any channel on the TV.
2* Point your Sky+ remote control away from the TV and press the tv button.
3* Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4. Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5*Point the Sky+ remote control at the TV and try the volume button.
If this works try the other TV functions.
If these work then the correct code has been selected.
It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
OK.
Aug 25, 2011 | Goodmans GTVL19W17HDF 19 in. LCD TV
Won't turn on.stand-by light flashes.timers are
my Sony trinitron kv-g21s2 TV not working . conned to the power blink in TV power indicator led
May 29, 2011 | Sony FD Trinitron WEGA KV-13FS100 13" TV
I want to remove goodmans 26" lcd stand. can you
You have to remove the back panel, and after that you will be able to get to the screws that is holding the stand on.
Nov 12, 2010 | Goodmans GTVL32W27HDF 32 in. LCD TV
My goodmans ld3265d1 has no standby light the mains and fuse is fine
I found with mine if i had a hdmi lead plugged in this would happen, if you plug the lead in after it works fine.
Aug 04, 2010 | Goodmans GTVL32W27HDF 32 in. LCD TV
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Lcd tv turns off after 5 mins, leave 2 mins comes on to stand by
Swollen ( bad ) caps in power supply first place to look.............T.
Dec 17, 2008 | Samsung DLP HL-P5663W 56" TV
Goodmans GTVL32W27HDF 32 in. LCD TV Logo
Top Goodmans Televison & Video Experts
Steven Wander
Steven Wander
Raj Patel
Are you a Goodmans Televison and Video Expert? Answer questions, earn points and help others
