Hi, you say the fan in the freezer kicks on? You also have a fan located by your compressor and coil which is the condenser fan motor and condenser coil. This fan must also be running when the compressor is on.Make sure that the coil down below is clean on the front of it as it draws air across this coil to keep the internal head pressures down. Check all of these things. The small copper line coming off the compressor, discharge line should be almost hot. The larger of the lines is the suction line and will be very cool, almost condensating . If not, you may have developed a small freon leak which will cause these problems. Make sure that everything I said is working and clean, and if the small motor in the rear bottom is not running, you can get a new one at a appliance parts house and 2 wires will replace it. Do all of this and keep me posted.
Shastalaker7
