20 Most Recent Amana ASD2326HE Side by Side Refrigerator Questions & Answers
FREEZER FAN MOTOR MAY NEED REPLACED. THE EASIEST WAY IS TO TAKE OFF THE BACK PANEL IN FREEZER AND REMOVE THE FAN
MOTOR, TAKE IT TO THE NEAREST APPLIANCE PARTS STORE WITH YOUR MODEL NO.
EASY JOB.
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If
you need more help go here:
http://www.applianceaid.com/procedures.html
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Amana ASD2326HE... | Answered on Sep 06, 2011
Sounds like you may have a restriction or blockage, may also be low on freon
Amana ASD2326HE... | Answered on Aug 27, 2011
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
If you need more help GO HERE:
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Amana ASD2326HE... | Answered on Aug 22, 2011
If your unit has an ice at the door feature, you may need to pull the whole bin out and make sure when you put it back in that you rotate the cork screw inside the bin 90 degrees so it seats properly to the spindle that turns it. I have had that problem after pulling the bin out to retrieve ice by hand ( because my dispenser is excruciatingly slow ), then when you push it back in it does not seat properly to the drive spindle , the whole bin sticks out enough to cause the door not to seat properly and will pop open. Try that. Good luck! George.
Amana ASD2326HE... | Answered on Jun 09, 2011
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Amana ASD2326HE... | Answered on Apr 08, 2011
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Amana ASD2326HE... | Answered on Dec 27, 2010
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
fsjksfyj
Amana ASD2326HE... | Answered on Sep 29, 2010
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Amana ASD2326HE... | Answered on Sep 24, 2010
There is a heater element that comes on to slightly melt the cubes from the tray... and let the arm discharge them into the bin.
It might be bad - or the motor for the fingers may be out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Amana ASD2326HE... | Answered on Aug 27, 2010
Sounds like the control module has gone u/s or you have a blockage which overloads the motor and causes it to shutdown in order to prevent damage occurring. Check there is no ice jammed in the dispenser and make sure that the water filter is clean and replaced every 6 - 9 months. if not then call a service engineer as either the motor, inlet valve and / or control module will need replacing.
Amana ASD2326HE... | Answered on Oct 10, 2009
your water line to the fridge is most likely leaking. You should turn it off right away. The line turn off is either behind the fridge or under sink. sometimes its in basement. The line is very easy to replace. You can get the plastic ones at home centers for under 5 bucks.
Amana ASD2326HE... | Answered on Sep 21, 2009
First of all, there is only one thing that cools in a fridge and that is the freezer. The fresh food section is cooled by air forced into it from the freezer.
  • You ice maker will not work if the temp inside the freezer is above 5 degrees. It has a thermostat inside it that enables it.
  • The knob that turns the fridge off and on is the thermostat for the freezer.
  • The other knob opens and closes a damper between the freezer and fresh food section.
  • There is a fan that should be running that pulls air from the freezer into the fresh food section.
(The factory does make the discription of the knobs confussing)
Now. turn one of the knobs all the way one way and then the next. If it turns the compressor off, it's the thermostat. If it does not, try the other knob. Once you find the thermostat, set it in the middle of the scale. Now place the other knob the same. Check and see if you can either feel or hear the inside fan running. If so lets go to the back. This is where your compressor is. It is under the fridge and also has a fan that blows on it. You will need to remove the back bottom panel. See if you can tell if the fan is running. Also notice if the fan is blowing into a set if coils. You should also be able to fill the compressor, if it's hot, it's running. If these two are running, and you didn't see a coil at the fan. Take the front kick panel off the fridge and clean the coil that's under the fridge. If it's dirty, give the fridge a couple hours and see if it cools down. If so, this was your problem. If both knobs are set mid scale, both fans are running, the compressor is also running and the coils are clean. You most likely have a bad timer, compressor or thermostat. This is all that's left.
Please rate solution
Amana ASD2326HE... | Answered on Sep 16, 2009
the water line could be froze comeing in to ice maker
Amana ASD2326HE... | Answered on Aug 24, 2009
Is this burning smell occurring during a defrost? Something, like a food particle or wrappping, could be burning while in contact with the defrost heater. Is the burning smell coming from within the freezer? If it is coming from the outside and back of the box, unplug the box and investigate, or call a technician. You may want to call a technician, anyway? We don't need house fires.
Amana ASD2326HE... | Answered on Jul 07, 2009
Hi TBurl,
Yeah... classic sign of a failed water valve. You need a new one. The part number is D7742204 (<---plug that into a search engine or call a local appliance parts outfit to get one).
Easy to replace... Just pull the fridge out, UNPLUG IT FROM THE WALL, turn the water valve off at the wall, remove the water line from the fridge valve, then remove the 2 screws mounting the valve bracket to the base of the fridge. All you have to do now is remove the electrical connectors and the tubing from the old valve and place them on the new one (making sure to get the wires right, OK?). Now just mount the new valve, reconnect the water, turn the water on and plug it in!
EASY! All in all about a 20 min. job. There ya go! Your fixed. Don't forget to rate this solution, OK? My self-esteem is depending on you. :P
SG
Amana ASD2326HE... | Answered on Jun 04, 2009
I had the same problem.... Until just one day the water quit working... Always thought it was hard water build up blocking the waterline.... Come to find out several years later all it was, was the dual water valve that had gone bad... I guess they have a censor in them that will either lock open or lock shut.... Mine was locked shut... When I tried to fix the valve myself, by opening it up and blowing air threw it, I locked it open and when I conected it back up to the fridge water was coming out of the door uncontrolably. So I ordered a new water valve.. Replace it myself... Works great now.... Hope this helps...
Amana ASD2326HE... | Answered on Oct 11, 2008
Cleaning the fins is always good. Is the fan by the compressor running? It needs to help cool the compressor. The description you mention sounds like the compressor is overheated and tripping the thermal overload on the compressor. See if you can turn if off for a day to let it all return to room temp then see if the compressor kicks on. If it was overheated it should run again for a while before overheating again. Let us know how that works and we can go from there.
Amana ASD2326HE... | Answered on Jun 08, 2008
Amana ASD2326HE Side by Side Refrigerator Logo
Popular Tags
162 questions posted
Top Amana Refrigerators Experts
Steve Allison
Steve Allison
Thomas F. Schneider
Marvin
Marvin
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
Amana Refrigerators
  • Amana Refrigerators
Most Popular Question
fridge freezer same temp
  • Refrigerators
