It's a simple enough setup, with a battery(18v), a globe(18v), a switch, and for some reason a circuit board with do-hickeys on it. I bypassed the circuit board and it then worked fine, but you may want to trouble shoot a bit.
-check for voltage in the globe holder
take it apart. use a multimeter on its beep setting.
-connect to either side of the switch and see if it works
-connect the battery and see if you get voltage across the pivot contacts.
see my solution here for how to dissemble, and how to bypass the circuit board
http://www.fixya.com/support/t15194423-remove_case_head_from_makita_bml185w
