Hi gomeryandgee,
If the symptom didn't cure by convergence
adjustment through the remote control, this is an
indication of faulty convergence board inside. You may replace
the convergence IC's and some of the resistor around because its already gone bad http://www.tvrepairworld.com/mitsubishi_repair_kits.
You may also replace the entire convergence board for your convenient. If the
board replaced with new one, your unit will back to normal again. Also, consider bad solder joints in that area,
it will do the same symptom like what you've encountered right now. Find it first
and re-solder. If you
don't have necessary tools and
test instrument and can't do
the job yourself, I would advice you to look for a qualified technician to isolate the problem.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
