Although your description is a bit vague, there are standard causes for low pressure that can be addressed.
The first is air in the line. Turn on the hose feeding the unit before attaching it. This will get any air in the hose out.
The pressure at which the water is delivered to the target is controlled by the nozzle. The narrower the pattern, the higher the pressure.
Also note that the detergent siphon normally works with only the lowest pressure nozzle (usually the black one).
As far as what the 'correct pressure' you are speaking of is, you would have to elaborate a bit more.
