Question about Karcher G 2600 VH Gas Pressure Washer
What viscosity oil is recomended for oil change?
Posted by dduppy on
Bruce Robin
  • 300 Answers
  • Gasoline-powered pressure washers use an SAE 30W motor oil (10W-30) in the engine. Always consult the engine manual for specific instructions and be careful to put the correct oil in the correct place.
Posted on May 24, 2010
Can you use other oil in a mazda tribute like GTX high Mileage 15W-50
personally i would advise staying with the manufacturers recomende oil, maybe go with a fully synthetic version
Dec 26, 2014 | Mazda Cars & Trucks
2009 chev impala has a clicking noise after the car is on
Check the Oil specification viscositi and type example 5W/20 or 5W/30 or 10W/20 or 10W/30 you shoud be know witch ones the factory recomend cause if you changed may is the fail
May 23, 2012 | Chevrolet Impala Cars & Trucks
I need to change my car engine oil what you
10w-40 is a good oil.
If your Mercedes has a lot of wear on the engine 15w-40 will stay in a while longer.
Enjoy,
Wayne
May 04, 2011 | 1999 Mercedes-Benz E-Class
My lifters are noisy and what would be the best oil additive to add to my oil to help with the noise 2001 mitsubishi galant
well first try flushing the engine with a motor flush incase the noise is from sticking lifters..than when you change the oil i recomend lucas oil treatment..it not only improves the viscosity of the oil but coats the parts much better than any other additive ive ever seen
Feb 23, 2011 | 2001 Mitsubishi Galant
Oil capacity with filter and what type?
Straight out of the manual!
RECOMENDED ENGINE OIL FOR HONDA VTX1300S
Pro Honda GN4 or HP4 (Without molybdenum additives)
4-stroke or equivalent motor oil
API service classification: SG or higher
JASO T 903 Standard: MA
Viscosity: SAE 10W - 40
OIL CAPACITY
3,5 Litre 3.1 Imp. Qts 3.7 US Qts at draining
3.7 Litre 3.3 Imp. Qts 3.3 US Qts at filter change
4.3 Litre 3.8 Imp Qts 4.5 US Qts at dissassembly
Jan 06, 2011 | 2004 Honda VTX 1300
Wat kind of oil should i use on my harley fatboy
the motor company says use only harley davidson 30 wt or better, but I use regular old motor oil.
Jul 09, 2010 | Harley Davidson Harley-Davidson Motorcycle...
Doe i use 10w-30 or 5w-30 oil when changing oil in my 2000 jeep wrangler in-line 6?
Multi viscosity oil use is dependant on the average temperature whare you will be driving. Read the can/bottle for recomended temperature range for the oil you are looking to use.
Aug 01, 2009 | 2000 Jeep Wrangler
Transmission fluid change interval for Mercedes C230 Kompressor
hi, mercedes are good for 200,000 before you change transmission oil, hope this helps my E300 has done 350,000 and still changes fine as the oil is not a lubricant as such it lasts longer and does not lose it's viscosity, hope this helps you, thanks for useing fixya
Jan 05, 2009 | Mercedes-Benz C230 Cars & Trucks
Right oil for my car
you want to use the 5w20 for best fuel efficiency and easier cold starts especially in bc. multiweight oil has made great strides in the years past. also synthetic oil is a good alternative but you should also use the manufacturer's recommended viscosity. the thinner oil also allows better lubrication on smaller passageways.
Dec 19, 2008 | 1997 Honda Accord
Karcher G 2600 VH Gas Pressure Washer Logo
488 people viewed this question
Top Karcher Garden Experts
Bruce Robin
Tim Venetis
JOHN LAPIER
Are you a Karcher Garden Expert? Answer questions, earn points and help others
