SOURCE: my internet provider doesnt support belkin wireless modem
Let me know the Service provider and the make and model of the previous modem. and also elaborate the problem with belkin.
SOURCE: wireless router to modem problems
Since it says network cable unplugged on the computer when wired to the router, you need to check these first:
â Make sure that the Ethernet cable is connected from the modem to the router’s Internet (WAN) port and the computer to the numbered port of the router. The computer should used to be connecting to the Ethernet port of the modem, if not; you should contact your ISP first.
â Make sure that the Ethernet adapter/LAN card on your computer is working properly. You can check that on the device manager of your computer.
â If those are all working fine that would mean the router is not yet configured for Internet access or we can say that the settings for the provider are not synchronized with the router.
To configure the router, you can do these general steps:
1. Connect the computer to the numbered port of the router and the modem to the router’s Internet (WAN) port.
2. Turn off the computer, router and modem.
3. Turn on the modem first, wait for the lights to stabilize then turn on the router. As soon as the lights are stabilized, you can turn on the computer and check for internet connection.
However, if the Internet connection still does not work. That means there are additional settings needed to be done. You can message me about the name of your ISP and I will provide you the specific steps you need.
SOURCE: modem light blinking and no internet in the
you have to unplug your cable modem before you connect the router. after you have connected the router you plug the power back on the cable modem then the router and you should be able to browse the net
SOURCE: Belkin Wireless N router/Embarq 660 modem/No internet
THE PROBLEM IS THAT THE BELKIN RTR AND THE 660 HAVE THE SAME IP ADDRESS THE QUICKEST FIX IS TO RENAME THE LAN IP ADDRESS OF THE BELKIN RTR
SOURCE: Modem Light Flashing, Internet Light Off, No Internet Connection
Hi, Here is your solution.
Please ensure the proper physical connection from modem to router and to the computer as mentioned on the box and make your all lights are on modem.After that turn on the router,if your have a cable modem, you can very well go for a hard reset,that it is at the back of your router you would see a reset button which is a button inside a hole. Please hold the button for 20 secs with power on router and 20 seconds without power continuously for 3mins (remember to hold the reset button through out 3 mins while plugin and plugout the power cord of the router and use pin or pen to hold the button). After this check out the lights on your router, lan light, internet ,power and modem should be solid.Else you can call the customer service number on the product box, they will assit you very well,ITS A TOLL FREE NUMBER.
