Reset the Control Panel
A power surge or outage may cause the "Clean" light to flash continuously after power is restored. Pressing the buttons on the panel in order and within 5 seconds resets the control panel and turns off the flashing light. The buttons must be pressed in the following order: "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash." After pressing the buttons, your Kenmore dishwasher will begin a short, 12 minute test cycle and reset the control panel.
Door Switch
A broken door switch can keep a Kenmore dishwasher from operating correctly, resulting in a flashing "Clean" light. Testing the door switch requires removing the door panel to access the control panel holding the switch in place. A continuity tester can determine if the switch has failed once you remove it from the door. Replace the switch if it fails to pass the continuity test. Make sure to disconnect the electricity to the dishwasher before accessing the switch.
I hope this helps.
F9 is a door lock error and to solve this issue you can hold
the light switch for 15 seconds, this will reset the control. If it won't work
then hold the light switch in and set the unit to clean and after a minute
press cancel to cancel the clean cycle. If still it won't work then the door
lock assembly should be replaced. Hope this helps...please post
back for further assistance.
Hi Thanks
for using FixYa. If the clean light flashes 7 times, pauses, and then repeats. When
the dishwasher doesn't sense a water temperature increase, it stops working and
locks the functions (clean light flashes 7 times, all buttons are non responsive).
It does this as a safety in case the element is broken and feeding electrical
current into the water.
To resolve this you will have to reset the console. Do this by closing the door
and press these buttons in sequence...
-high temp wash -heated
dry -high
temp wash -heated
dry
All the lights will turn on briefly and the machine will start a diagnostic
cycle. You can press cancel or let the diagnostic cycle finish (1-2
minutes). You should now be able to run the dishwasher as normal. If the
issue returns, you could have a problem with the heating circuit (i.e. element,
thermostat or wiring). It rarely happens but it could also be the door
switch not engaging properly when the door is closed (slightly bend the door
latch down making sure it doesn't hit the door when you close it). Please
do rate the solution if the issue is resolved or post a comment for further
assistance. Thanks Rylee
Hi Thanks
for using FixYa. If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it stops
working and locks the functions (clean light flashes 7 times, all buttons are
non responsive). It does this as a safety in case the element is broken and
feeding electrical current into the water.
...all the lights will turn on briefly and the machine will start a diagnostic
cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
If the issue returns, you could have a problem with the heating circuit (ie.
element, thermostat or wiring).
It rarely happens but it could also be the door switch not engaging properly
when the door is closed (slightly bend the door latch down making sure it
Please do rate the solution and revert for further assistance.
When
the dishwasher doesn't sense a water temperature increase, it will
stop working and lock the functions (clean light flashes 7 times, all
buttons are non responsive). It does this as a safety in case the
element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
...all
minutes).
If
(ie. element, thermostat or wiring). It rarely happens but it could
also be the door switch not engaging properly when the door is closed
(slightly bend the door latch down making sure it doesn't hit the door
when you close it).
...all
When
...all
If
when you close it).
If the clean light flashes 7 times, pauses then repeats...
If the dishwasher doesn't sense a water temperature increase, it will
...all
If
when you close it).
When
...all
If
when you close it).
