The screen has gone blank it won't print and there is a red exclamation mark
Yes, I had the same problem. I found the answer after a lot of searching but it involved having to re-solder a part on the board for the LED screen. A bit tricky but it worked. Did that several years ago and the printer is still working.
Thanks to John Phillips who responded on the FixYourOwnComputer.com about how to fix this problem. I followed the instructions and my Epson has been operating for several years without further problem:
1. Ease off the plastic facia that covers the control buttons - (no screws - it just clips on)
2. Remove the cross head screw that is seen to the bottom left of the display unit.
3. Flip display unit open - remove the cross head screw that holds the dark plastic support clip that is behind the unit and top right ish!!
4. Remove the display unit - unscrew the 4 small cross head screws that hold the display assembly together - NOTE THAT THE CONNECTING RIBBON RUNS THROUGH THE HOLE - I didn't make a note at first, and it took me ages to work out where it went when trying to re-assemble it !!
5. Mark the connecting ribbon so that you know which way up it should be, then carefully pull it away from the black connecting block - Re-assemble merely by pushing it carefully back into place.
6. On the circuit board you will see a large (ish) black Integrated Circuit - using a magnifying glass you will see a tiny soldered fuse marked F1 just to one end of this Integrated Circuit.
7. Using a single strand of clean copper wire ( a single strand taken from a multi strand piece of speaker wire is ideal) carefully solder it across the two terminals
8. Having a soldering tip small enough is vital if you are to attempt this - an ordinary tip is TOO BIG. I used a piece of copper earth wire (obtained from ordinary "Twin and Earth" electricians household mains wiring cable) I then wound it around my soldering tip and filled it down to a fine point.
9. Re-assemble - switch on - and if you have been careful and succeeded in this feat of micro soldering - you should have a realistic chance of having a fully functioning display once again.
- jegohio
Did anyone fin the answer to this? It happened to me too.
