SOURCE: Frigidaire Electric Range ES200/300
there is sometimes a thermal fuse inside the caseing might have to take the top off if not then you will need a new timer be safe and unplug
SOURCE: stove works, oven does not
in repairing Kenmores there is a relay well 2 small black an square in the head unit of stove one for stove the other is for oven anyway they go out alot a setback to the kenmore digital controls take upper panel off where controls are look at the green board an you can see them some green some red or blue to tell if one is bad be careful an turn the stove on u will hear the relay click then try oven if you do not hear a click its bad do not i repeat do not touch it while its on
SOURCE: The digital clock on my Frigidare electric stove
make sure your power connector is tightly plugged into the outlet- also, check for any signs of possible rodent (no offense!) damage to the wiring! sometimes it's hard to tell if the little devils are lurking about!you may want to unplug the cord and inspect for corrosion. you may want to turn off the breaker for the stove. i assume it's 220 volt. then spray plug with a little WD40. let it dry a bit, and plug it back in, then reset the breaker! if that isn't it, you may have a loose connection, or more inside your stove. in that case, get a pro to check it out!! then do the math- will it cost more to fix it than it will to replace it?? your choice!
good luck!
my frigidaire oven will not light. The broiler works and the oven ingiter lights up, but the oven will not ingite. The electronic display does work.
