Your best bet for initial startup and first 100 miles is to stick with stock plugs and gap. Then alter depending on what you see with plug condition. More likely you will need a different plug TYPE, depending on mods. If you have increased horsepower and/or compression ratio (depending on what you see after 100 miles), go with colder plug, and stay with current gap. If setup is now runs a little ''smokey'' (i.e. ''rich'' mixture and/or burning oil), go with hotter plug and stay with current gap.
With points cover off,slowly bring engine to the highest point on the points cam.Its easiest to do this with the spark plug out,and slowly spin the engine with the kick start. Once you get it to the highest point on the points cam,the points should be "open". Insert feeler gauges untill you find the correct one...(it should have slight resistance). The check what the recommended gap is for that model. After finding the recomended gap,use the feeler gauge that matches the recomended gap,and isert between the points. There should be two screws,one on each end of the points. Loosen those two screws,and the body of the point will move,one way to "open": the gap,the other to "close" the gap. With feeler gauge between the points contact,close untill you feel slight resistance when moving the gauge back and forth,and tighten the set screws on the points body.
You are probably dealing with dirty,burnt,or shorting points. Try replacing the points located at the end of the crankshaft under the cover held on by two screws. You may have to install and reinstall the points several times before you can get the new points to work. Chances are the points in the machine are almost 40 years old. Also , Honda ignition systems run off the battery. In most Honda models if you do not have a good, charged battery , you will not get spark.
