Microsoft Office Professional 2007 Full Version for PC Logo
Posted on May 05, 2010
How to make dialog box in word file
How to made a form for submission to company. 下拉式
How can I apply for Edgars account on line?
Hello, call edgars cust service and apply there.
How to print database in vb
To Print a Database you would require to create a Report. There were many ways of creating reports in Visual Basic 6.0. Hereby I am giving you an example of Data Report.
Printing a Data Report
Printing a data report can be accomplished in one of two ways. The user can click the Print button that appears on the data report in Print Preview mode (using the Show method), or you can programmatically enable printing using the PrintReport method. If an error occurs during printing, trap it in the Error event.
Choosing to Display a Print Dialog Box
When printing a report programmatically, you have two choices: to print by displaying the Print dialog box, or by printing without displaying the dialog box.
To display the Print dialog box
  1. Add a CommandButton to a Form.
  2. In the button's Click event, place the following code.
DataReport1.PrintReport True The Print dialog box allows the user to select a printer, print to file, select a range of pages to print, and specify the number of copies to print.
Note Printers must be installed on the computer in order to present a choice of printers.
Printing Without a Dialog Box
In some cases, you may wish to print the report without user intervention. The PrintReport method also gives you the option of selecting a range of pages to print, either all, or a specified range.
To print without displaying the dialog box
  2. In the button's Click event, place the following code:
DataReport1.PrintReport False
Or, to specify a range of pages to print, use the code below:
DataReport1.PrintReport False, rptRangeFromTo, 1, 2
Dear sir yesturday i download anti virus & office2007, & i m not able to find this programe & also before i have cyber link webcame not i cant find,also & it is not working also,
Depending on the operating system for your computer, downloaded files can be on the Desktop, in a folder called Downloads or My Downloads, or your My Documents or Documents folders.
According to the HP website, this operating system should be Windows XP.
If you do not know the name of the files that you downloaded, you cannot search for them.
To find the folder that your downloads go to:
EASY WAY: Go to http://regserve.spywaretruth.net; click on the download now button in the middle of the screen. When the dialog box pops up it will ask you to save the file. Click on this Save File button. The next dialog box will show you at the top, the name for the folder your downloads go to. If this dialog box says Desktop, your files will be on the main start-up screen. If it says My Documents check that folder. If it says Downloads, check the folder above it by clicking on the BLACK ARROW to the right of the Save in folder name. Look at the folder name above the Downloads folder. Usually this folder is called My Documents. In this case the folder you are looking for can be found by double clicking on the My Documents Folder, then looking for Downloads.
If this helps you, please accept my answer.
4helpful
Can't save Adobe Acrobat 9 fillable forms
Fill in an interactive pdf form After you fill in the form fields, do any of the following:
  • Click the submit form button. Clicking this button sends the form data to a database across the web or over your company intranet.
  • In Acrobat, choose File > Save As, and rename the file to save the form with the data you entered.
  • In Reader, choose File > Save A Copy, and specify a location for the copy. Note: If the form author gave Reader users extended rights, the saved copy will include the entries you made in the form. Otherwise, the saved copy will be blank.
Enable Adobe Acrobat Reader users to save form data Ordinarily, Reader users can’t save filled-in copies of forms that they complete. However, you can extend rights to users of Reader 8 and later so they can do so. In Acrobat Pro and Pro Extended, these rights also include the ability to add comments, use the Typewriter tool, and digitally sign the PDF.
  1. Open a single PDF, or preview a component PDF in a PDF Portfolio.
  2. If you are editing the form, click Close Form Editing in the upper-right corner of the form.
  3. Do one of the following:
    • (Acrobat Pro and Pro Extended) Choose Advanced > Extend Features In Adobe Reader.
    • (Acrobat Standard only) Choose Advanced > Extend Forms Fill-In & Save In Adobe Reader.
    These extended privileges are limited to the current PDF. When you create a different PDF form, you must perform this task again to enable Reader users to save their own filled-in copies of that PDF.
If you don’t want recipients to overwrite the blank form template by saving form data, do not extend rights in the copy you send to them.
Limitations on saving filled-in forms locally
Acrobat Standard, Acrobat Pro, and Acrobat Pro Extended each allow Adobe Reader 8 or later users to fill in and save PDF forms locally. The use of the Reader Extensions capability for local saving of PDF forms (called extended documents) is limited in two ways:
Number of deployed extended documents An Acrobat Standard, Acrobat Pro, or Acrobat Pro Extended customer can send an extended document to an unlimited number of recipients for them to fill in. For example, an Acrobat customer can post an empty form template on a web page that allows users to fill in and save PDF forms locally. An unlimited number of people can access the template. However, the Acrobat customer can collect only 500 responses from the filled-in form. This limitation includes both hardcopy (paper form submission) and electronic representations of the filled-in form.
Number of recipients of the extended document An Acrobat Standard, Acrobat Pro, or Acrobat Pro Extended customer can send an extended document to no more than 500 unique recipients. For example, an Acrobat customer belongs to an organization with 500 people or less. The Acrobat customer can send an unlimited number of copies of the extended document to those 500 recipients and collect unlimited responses from the filled-in form.
Both limitations apply per entity/company, and multiple users in an entity cannot abuse this feature. Obtaining additional licenses to use Acrobat Standard, Acrobat Pro, and Acrobat Pro Extended does not increase the above restrictions. For example, five Acrobat Standard 9 users in a company cannot send out the same extended document to receive and extract data collectively more than 500 times.
Acrobat Standard, Acrobat Pro, and Acrobat Pro Extended include technology that can enable PDF documents with certain features by using a digital credential. This credential is located within the Software (“Key”). You agree not to access, attempt to access, control, disable, remove, distribute the Key for any purpose.
I hope it helps.
Regards
1helpful
2answers
No voice recognition
You must have already set up and trained a user with the Dragon NaturallySpeaking software prior to transcription. Make sure that the Digital Voice Editor (DVE) software is not opened prior to starting these steps.
Open the Dragon NaturallySpeaking software.
The Dragon Bar window opens. From the Dragon Bar menu, click the Sound button.
From the Sound button, select the Transcribe Recording menu item.
The Transcribe a Recording dialog box opens.
Click the large square button to the left to start the DVE software.
The Digital Voice Editor window opens.
NOTE: If the file you want to transcribe is still on the Integrated Chip (IC) recorder (which will be reflected on the left side in the IC Recorder window), you will need to connect the IC recorder to the computer using the supplied USB cable, or transfer the file to the computer.
Select the item you want to transcribe from the PC window on the right side.
Click on File from the tool bar.
Select the Voice Recognition menu item.
The Converting.. Dialog box opens.
The Transcription Options dialog box opens.
Click the Transcribe button to continue.
The Transcribing window and Dragon Pad window opens.
The text is displayed while the transcription is in process.
NOTE: Once the transcription is complete, it may be necessary to make grammar, word, punctuation, and formatting adjustments.
To save the text file, click on File from the tool bar.
Select the Save As. Menu item.
The Save As dialog box opens.
Browse to the folder location to which you want to save the text file and double-click on that folder.
The folder you chose should now be showing in the Save in drop-down box near the top.
Type in the desired File name in the File name drop-down box towards the bottom and then select the document type.
Click the Save button.
Click the X (close) button in the upper-right corner to close the Dragon Pad window.
Click the X (close) button in the upper-right corner to close the Digital Voice Editor software.
I cant log out of facebook
Try deleting your cookies. Use one of the below options: How to manually delete cookie files in Internet Explorer 8 loadTOCNode(2, 'moreinformation');
  1. Exit Internet Explorer 8, and then exit any instances of Windows Explorer.
  2. Do one of the following:
    • In Windows Vista, click Start Collapse this imageExpand this image vistastartbutton.jpg, type inetcpl.cpl in the Start Search box, and then press ENTER
    • In Windows XP, click Start, click Run, type inetcpl.cpl in the Open box, and then press ENTER.
  3. On the General tab, click Delete under Browsing History in the Internet Properties dialog box.
  4. In the Delete Browsing History dialog box, click to clear all of the check boxes except for the Cookies check box.
  5. Click Delete.
To verify that the cookie files are deleted, follow these steps:
  3. In the Internet Properties dialog box, on the General tab, click Settings under Browsing History.
  4. In the Temporary Internet Files and History Settings dialog box, click View Files. This opens the folder where your cookie files are stored.
  5. In the folder that you opened in step 4, verify that there are no .txt files.
How to manually delete cookie files in Internet Explorer 7 loadTOCNode(2, 'moreinformation');
  1. Exit Internet Explorer 7, and then exit any instances of Windows Explorer.
    • In Windows Vista, click Start Collapse this imageExpand this image vistastartbutton.jpg, type inetcpl.cpl in the Start Search box, and then press ENTER.
  4. In the Delete Browsing History dialog box, click Delete Cookies.
  5. In the Delete Cookies dialog box, click Yes.
To verify that the cookie files are deleted in Internet Explorer 7
How to manually delete cookie files in Internet Explorer 6 loadTOCNode(2, 'moreinformation');
  1. Exit Internet Explorer 6, and then exit any instances of Windows Explorer.
  2. Click Start, click Run, type inetcpl.cpl, and then press ENTER.
  3. On the General tab, click Delete Cookies in the Internet Properties dialog box, under Temporary Internet Files.
  4. In the Delete Files dialog box, click to select the Delete all offline content check box, and then click OK.
To verify that the cookie files are deleted for Internet Explorer 6:
  2. Click Start, and then click Run, type inetcpl.cpl, and then press ENTER.
  3. In the Internet Properties dialog box, on the General tab, click View Files under Temporary Internet Files.
  4. In the folder that you opened in step 4, verify that there are no text files.
10helpful
AppHangXProcB1
Step 1: Open a blank page in Internet Explorer loadTOCNode(2, 'resolution'); Test Internet Explorer by opening a blank page. To do this, follow these steps:
  1. Click Start, click Run, type iexplore about:blank in the Open box, and then click OK.
  2. If Internet Explorer does not start, go to "Step 3: Start Internet Explorer in 'No Add-ons' mode." If Internet Explorer starts correctly, follow these steps to use a blank page as your home page:
    1. On the toolbar, click Tools, and then click Internet Options.
    2. On the General tab, note the address that is listed in the Home page area. This address may cause the problem.
    3. Click Use Blank, and then click OK.
    4. Close Internet Explorer. Then, start Internet Explorer again.
uparrow.gifBack to the top Step 2: Remove temporary Internet files, browsing history data, and Web form data loadTOCNode(2, 'resolution'); To remove temporary Internet files, browsing history data, and Web form data, follow these steps:
Windows Internet Explorer 8
  1. Start Internet Explorer.
  2. On the toolbar, click Tools, and then click Internet Options.
  3. On the General tab, click Delete in the Browsing history area.
  4. In the Delete Browsing History dialog box, click to clear all of the check boxes except for the following check boxes:
    • Cookies
    • History
    • Form Data
  5. Click Delete.
  6. Click OK to close the Internet Options dialog box.
Windows Internet Explorer 7
  4. In the Delete Browsing History dialog box, click Delete files, and then click Yes in the Delete Files dialog box.
  5. Click Delete cookies, and then click Yes in the Delete Cookies dialog box.
  6. Click Delete history, and then click Yes in the Delete History dialog box.
  7. Click Delete forms and then click Yes in the Delete Form Data dialog box.
  8. Click Close, and then click OK.
Test Internet Explorer to verify that it works correctly. If problems still occur, go to the next step. uparrow.gifBack to the top Step 3: Start Internet Explorer in "No Add-ons" mode loadTOCNode(2, 'resolution'); To start Internet Explorer in "No Add-ons" mode, click Start, point to All Programs, point to Accessories, point to System Tools, and then click Internet Explorer (No Add-ons). To continue to your home page, click the Home button.
If the problem does not occur after you use this method, use Manage Add-ons to determine which add-ons are causing the problem. To do this, follow these steps:
  1. Click Tools on the Internet Explorer toolbar, and then click Manage Add-ons.
  2. Click the name of the add-on at the top of the Toolbars and Extensions list, and then click Disable.
  3. Click Close, and then test Internet Explorer.
  4. If the problem still occurs, open Manage Add-ons, enable the add-on that you disabled in step 2, and then repeat steps 1 through 3 for the next add-on in the Toolbars and Extensions list.
  5. Repeat steps 1 through 3 until the problem is resolved or until all the add-ons have been tested.
  1. Click Tools on the Internet Explorer toolbar, point to Manage Add-ons, and then click Enable or Disable Add-ons.
  2. Click the name of the add-on at the top of the Enabled list, and then click Disable in the Settings area.
  3. Click OK, and then test Internet Explorer.
  4. If the problem still occurs, open Manage Add-ons, enable the add-on that you disabled in step 2, and then repeat steps 1 to 3 for the next add-on in the Enabled list.
  5. Repeat steps 1 to 3 until the problem is resolved or until all the add-ons have been tested.
uparrow.gifBack to the top Step 4: Use another user name to log on to Windows loadTOCNode(2, 'resolution'); Using a different user name and password to log on to Windows can help determine whether this problem occurs only when you use a particular user account. After you log on, test Internet Explorer to see whether the problem still occurs. uparrow.gifBack to the top Step 5: Reset Internet Explorer settings loadTOCNode(2, 'resolution'); To reset Internet Explorer settings, follow these steps:
  2. Click Tools on the toolbar, and then click Internet Options.
  3. On the Advanced tab, follow one of these steps:
    • In Internet Explorer 8, click Reset, click Reset in the Reset Internet Explorer Settings dialog box, and then click Close.
    • In Internet Explorer 7, click Reset, and then click OK.
  4. Test Internet Explorer to determine whether the problem is resolved.
Name some common dialog boxes and mention its uses.
There are numerous common dialog boxes in windows, please note i am very specific to windows (and not VB since VB has difference nominclature for common dialog boxes)
following are some windows common dialog boxes:
  1. UserInput dialog box: to fetch user input.
  2. Alert dialog box: to display some alert information to the user.
  3. File Open Dialog Box: to browse and open file from selected filesystem.
  4. FileSave dialogbox: to save a file to a filesystem on selected path.
  5. Print dialog box: to setup printer preferences and print setting commands routing to printer.
Thanks.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
