JVC KD-R200 Car CD/ MP3 Player Logo
Posted on May 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I hooked up my JVC KD-R200 to a 1991 Toyota Tercel and I can't get the face of the stereo to turn on. No sound, no radio stations, just the lights around and on the buttons come on. I have another stereo with the same wires and it works fine but I have no idea what is wrong with this one. All the wires are to specs and I've tried resetting it. Any suggestions?
Anonymous
Level 2:
Scholar:
  • Expert 84 Answers
  • Posted on May 01, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
84
Questions
0
Helped
45642
Points
200
Try reversing your red (accessory) and yellow (constant) wire... also check the fuse on the back of the radio. and it wouldn't hurt to clean the connector between the faceplate and the radio either corrosion can cause this....
How do i connect a mp3 player to a jvc kd-g331
if the deck doesnt have an auxilliary input or usb input then the only way to get sounds to it and through it is going to be by using an fm modulator that will broadcast your mp3 tunes through an fm signal that you choose and simply tune you radio to the station that you chose to broadcast through.
JVC KD-SH9101 RESET06 and the front panel don't move normally
ok from what i can gather it sounds like something broke inside the unit and you might wanna replace it. Im sure you can find a much better radio really cheap. I had a similar JVC model and it gave me headaches. I think you will love this model instead. Trust me its soooo much better and priced really well for its capabilities.
JVC KD-R800 30K Color-Illumination Single-DIN CD Receiver with Dual USB 2.0 for iPod/iPhone and Bluetooth
2helpful
Jvc kd-sx750 head unit has power but puts out no sound
bro to me it sounds like your radioi is bad you got everything hooked up right to get sound from it maybe the ant. hooked up but you should still get sound thats why I say the amp in the unit is bad!
here a little help: red: ignition when the key is turned on
yellow or orange: all time 12v
black: ground
blue: amp turn on, or auto ant.
Just installed KD-SH55 JVC in Tahoe myself, no lights on but ejec
if it has a face plate and most after market radios do then it may not have a good connection check and make sure it does maybe even clean them with alcohol also make sure you got a good ground it may not have enough power to come on all the way (<-- rarely is the case) but it sounds like a bad radio
40helpful
3answers
JVC KD-S15 setup - How do I turn "Demo" Off?
press and hold the sel button....select an itenm (useing the silver button beside the volume dial).....then use the volume dial to adjust ,time , demo alot of others...then press sel button to finish.....this is straight out of the instructions...hope it helps you
Sound turns on when it wants to.
disconnect all of your speakers , then hook them back up one at a time when the radio starts to malfunction u have located which channel on the radio is bad.check ur wire installattion
JVC KD -S680 needs help
all radios like your has two power inlets one is battery and the other is Acc or Ing. The battery line keeps power in the radio after you turn off your car both lines must work for the radio to turn on it sounds like a resister burn out thats why your face plate was warm.
Top JVC Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
 Grubhead
Grubhead
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
