Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
Posted on Apr 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Control Lock is on and I cannot change it? - Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
Anonymous
Level 3:
  • Master 949 Answers
  • Posted on Apr 24, 2010
Anonymous
Master
Level 3:
Answers
949
Questions
0
Helped
258802
Points
3036
Press and hold the cycle signal button for 5 seconds let go and see if that unlocks, let me know if not and send your complete model number and I will dig a bit deeper
The CL button is flashing on my display and I cannot select a wash cycle. I put my palm on the display inadvertently.
You enabled the Control Lock function; this is useful when you clean the control panel. It also keeps children from changing the settings when they shouldn't. Press and hold the Control Lock (bottom right of the Options buttons on the left side of the control panel) for 3+ seconds. You should hear a beep or see a change in the display message. If you hold the button too long, the control lock will toggle off and then back on. See https://www.manualslib.com/manual/1214570/Kenmore-Elite-796-3142.html?page=22 for the description of the Control Lock.
I hope this helps.
1helpful
CL code for lg LDF5545ST dishwasher this a pitture of front
, : Control Lock
The Control Lock feature helps prevent settings from being changed during a cycle. Selecting this feature locks all of the buttons, except for the Power button, on the control panel. This feature does not lock the door.
While a cycle is running, press and hold Half Load and Energy Saver simultaneously for three seconds to activate or deactivate Control Lock.
- To start a new cycle, deactivate Control Lock.
Whirlpool duet dreyer control lock On --can't program dreyer
try unplugging for a couple of minutes and it should reset to factory settings.
2answers
What causes a malfunction in power locks?
The power door locks are controlled by the BCM -body control module ! The door lock switch is an input to the BCM .
The BCM, upon receipt of a door lock switch lock or unlock signal, will switch the appropriate door lock actuator control circuits to battery positive voltage. The opposing side of the door lock actuators are connected to ground internally within the BCM through the other door lock actuator control circuit and the doors will lock or unlock appropriately.
First thing to do would be check power an ground circuits at the BCM ! Do you have any other systems not working -power windows etc...
The DR/LCK fuse supplies battery positive voltage to the I/P fuse block for the door lock system. The body control module (BCM) supplies and monitors a reference voltage to the door lock switch through the door lock switch lock/unlock signal circuit. The door lock switch also receives a constant ground source. If a door lock switch is placed in the lock position or unlock position, the reference voltage is taken directly to ground and the BCM detects the voltage drop on the signal circuit.
Should have BCM checked for stored DTC'S - diagnostic trouble codes !
Ignition ON, observe the scan tool Driver Door Lock Sw, Psgr Door Lock Sw, Driver Door Unlock Sw and Psgr Door Unlock Sw parameters while using the driver and passenger door lock switches. The parameters should change between Active and Inactive.
If the values does not change between the commanded states, refer to Door Lock Switch Malfunction.
Command the driver door and passenger door lock actuators to LOCK and UNLOCK with the scan tool, the doors should LOCK and UNLOCK when changing between commanded states.
If a door lock actuator does not perform the LOCK and UNLOCK functions, refer to Door Lock Malfunction
DTC B3130 00: All Door Unlock Circuit
DTC B3135 00: All Door Lock Circuit
How to unlock control panel LFFH21F7HWG?
Press and hold the Control Lock key for three seconds
to activate or deactivate the function. The Control Lock
feature prevents the user from changing the temperature
and freeze settings. At the first press of any key, the
key press click tone will be heard and the display will
show "LO", but no other change will take place. Holding
the Control Lock key for three seconds will activate or
deactivate the Control Lock feature. After three seconds,
the accept tone sounds and the Control Lock LED (if so
equipped) is activated. In lockout mode, when any key
is pressed, the invalid key tone will be heard and "LO"
will be displayed for 1 second. When the lockout is
deactivated, the Control Lock LED is turned off and the
display shows "UL"
if this does not work unplug the freezer for 30seconds then plug it in. if all of the above fails replace the control.
2helpful
Control lock stays on
  • 1
    Examine the control panel and locate the "Control Lock" button, sometimes located next to the "Lighticon1.png On-Off" button.
  • 2
    Press and hold the "Control Lock" button for a few seconds until the small red LED goes out.
  • 3
    Make your changes to the refrigerator'sicon1.png controls, or use the water and ice dispenser. Repeat step 2 to restore the control lock.
  • 0helpful
    Magnavox child lock help
    hello The parental control menu enables
    you to limit access to programs that
    may contain objectionable material
    or are not suitable for viewing by
    children. The default access code is
    0711
    0711.
    The following table provides details
    about the menu items:
    Component Function Range / Options
    Lock Enable
    Enables the parental control lock. When
    enabled, channels with objectionable viewing
    content are blocked and can only be
    accessed with a password. You can block
    channels according to the movie or TV ratings
    of the channel’s programs.
    Off, On
    Movie Rating Helps you block programs based on their
    movie ratings. See “Movie Rating” on
    page 25 for more details.
    TV Rating Helps you block programs based on their TV
    ratings. See “TV Rating” on page 26.
    Change Code Changes the password for the parental control
    lock.
    Press the number keys to
    change the password.
    Reset Resets all channels and programs to their
    default factory settings.
    regards
    shaun
    Parental Control Menu
    Lock Enable
    Change Code
    Reset
    Back
    Main Menu
    Sound
    Size
    PIP/PBP
    Parental Control
    Channel Setup
    Setup
    Exit
    Press Right to Enter
    Press New Code
    Off On
    TV Rating
    Movie
    2helpful
    Temperature control panel beeping
    There are 3 models with this model #,so not sure if your has lock.
    If it does and still changes,contact ge and tell them what is happening,maybe they will send you out a new control panel,if the warranty expired,depends.But it doesn't hurt to try.
    This feature allows you to lock the controls
    so the settings cannot be changed.
    To lock the controls:
    Set the controls to the desired settings.
    Press and hold the lock pad for
    3 seconds.
    When the controls are locked, the indicator
    light will come on and the control settings
    will not be displayed.
    To unlock the controls:
    Press and hold the lock pad for 3 seconds.
    After unlocking the controls, the settings
    will be displayed, the lock indicator light
    will go out and the settings can be changed.
    1helpful
    Door Lock
    remove spring around door seal ..roll seal back into door opening remove 2 screws on outer frame holding lock in place ..pull lock through opening remove wires reinstall in reverse..are you sure lock is broke if you hear a clicking noise when lock should be closing suspect loose connection on main control bd ..remove top control is gray box on rear rail..try wiggling connections toward center of control if lock energizes and works suspect control ..may be able to shim plug in place but sure fix would be new control
    Top Whirlpool Dryers Experts
    Virgil Watts
    Paul Bade
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
