Wear it how you like it 4
5
English
The Jabra BT160 is ready to wear on your right ear. If you prefer the left, gently flip and
rotate the earhook 180°. (
See fig. 2 )
For optimal performance,wear the Jabra BT160 and your mobile phone on the same side
of your body or within line of sight.In general,you will get better performance when
there are no obstructions between your headset and your mobile phone.(
See fig.5 )
Answer a call
Tap the answer/eend button on your headset to answer a call
End a call
Tap the answer/eend button to end an active call
Reject a call (DDependent on your phone supporting this feature)
Press the answer/eend button when the phone rings to reject an incoming call.
Depending on your phone settings, the person who called you will either be
forwarded to your voice mail or hear a busy signal
Make a call
• When you make a call from your mobile phone, the call will (ssubject to phone
settings) automatically transfer to your headset
Activate voice dialing (DDependent on your phone supporting this feature)
Tap the answer/eend button. For best results, record the voice-dialing tag through
your headset. Please consult your phone ’ s user manual for more information about
using this feature
Redial last number (DDependent on your phone supporting this feature)
Adjust sound and volume
Press the volume up or down (+or – ) to adjust the volume (
See fig. 1 )
How to...5
Before you use your Jabra BT160, you need to pair it with your mobile phone.
1. Put the headset in pairing 2 mode
Make sure that the headset is on.
Press the answer/eend button and
press the volume up (+) button at the same time,
until a solid blue light comes on.
2. Set your Bluetooth phone to ‘ discover ’ the Jabra BT160
Follow your phone ’ s instruction guide. This usually involves going to a ‘ setup,’
‘ connect ’ or ‘B luetooth ’ menu
on your phone and selecting the option to ‘ discover ’
or ‘ add ’ a Bluetooth device.** (
See example from a typical mobile phone in fig. 4 )
Pair it with your phone 3
English
Turn on your headset 2
Press the answer/eend button to turn on your headset
Press and hold the answer/eend button to turn off your headset
Charge your headset
Make sure that your Jabra BT160 headset is fully charged before you start using it. Use
the AC adaptor to charge from a power socket. Connect your headset as shown in fig. 3.
When the LED is solid blue, your headset is charging. When the solid blue LED turns off,
it is fully charged.
The Jabra BT160 is easy to operate. The answer/eend button on the headset performs
different functions depending on how long you press it.
Instruction:Duration of press:
Tap Press briefly
Press Approx: 1 second
Press and hold Approx: 5 seconds
Getting started
3. Your phone will find the Jabra BT160
Your phone then asks if you want to pair with it. Accept by pressing ‘ Yes ’ or ‘ OK ’ on
the phone and confirm with the
passkey or PIN 3 =
0000 (44 zeros).
Your phone will confirm when pairing is complete. In case of unsuccessful pairing,
repeat steps 1 to 3.
http://www.jabra.com/Sites/Jabra/UK-uk/support/Pages/JabraBT160.aspx
It is all in there
www.jabra.com
ARTGIRL
I have the same problem. My BT160 is not powering on even after fully charging it for several times..
It worked.
I found that I have to hold the answer/end button for about six seconds to get it to turn on or off.
Thank You.
AL
I received one in the mail, when I charge it appears to be charging. When I take it off the charger, no lights flash or anything. I tried to hold down that button and it does not turn on. NEED HELP!!!! Is it broken?
same problem here bought the damn thing yesterday , used it to connect to my ps3 ; it worked ;went to bed next morning dead, when i charge it the blue light goes on for 5 min then the light goes away meaning it should be fully charged but i cant get it to turn on anymore , no lights nothing
I have the same problem, the worst. The blue light is not on when charging first time and nothing happens when I tried to turn it on.
i am trying to turn my jabra 160 on and held the answer button on for 6 secs or more...I charged my wireless overnight and it still wont turn on what do i need to do
