G'day, sounds a bit like the float valve in the carby might be stuck nearly shut or just some moisture in the carby, a light tap with the handle of a screwdriver on the side of the carby bowl should fix it if it's the needle stuck shut (happens from sitting sometimes), or maybe try loosening the drain screw in the bottom of the carby bowl to drain any water etc out, hope this helps :)
I have the same problem with an '03 TTR 225. Was in storage about a year. Have drained fuel tank and carb bowl and replaced with fresh gas. Plenty of spark; air filter is clean. Did April question get solved?
It sounds like a fuel prob pos excel pump
