I go step by step on the screen, but when i get everything set up, it says it cant detect the router on my computer, I have a one of those digital phone modems for digital phone customers from roadrunner, do you think that may be the problem????
i got a d-link router and it is still saying that it cannot detect it, what is going on?????i got a d-link router and it is still saying that it cannot detect it, what is going on?????
You can't post conmments that contain an email address.
May I suggest a quick and easy fix, maybe not so cost effecient UNLESS you can return the linksys router. If you are using DSL, then I recommend a D-Link router for your access point. Linksys routers are commonly not compatable with DSL modems. If you get the D-link, you should have no problems with plug and play.
You will need to check the wireless settings of the router. If your network is secured then make sure that you are typing the correct network key. also make sure that the DHCP server is enabled on the router. is there any computer connected to the router ? If yes then you can open the router set up page on that computer. Router set up page is the page where you can check all the wireless settings of the router. Click here for step by step instructions
Are you trying to set up the router. You can do it manually without the CD. Make sure that your computer is able to go online through the modem. If your computer is not able to go online through the modem then you will need to call ISP first. If your computer is able to go online through the modem then you need to connect the computer to the router and the modem to the router. open the set up page of the router and change the settings of the router according to the ISP. Click Here for step by step by instructions
theres a couple of version of this router
http://www.dlink.com/products/default.aspx?pid=WBR-1310&tab=3
I'm using the manual from here
http://www.dlink.com/products/?tab=3&pid=WBR-1310&rev=WBR-1310
on a working PC download and install this program
http://www.xirrus.com/library/wifitools.php
this will detect all the wireless signals being broadcast - see if the router is actually broadcasting - if it is detected on your PC then it may be that 1) the firewall is blocking access or 2) the security code is entered wrong - -log into the router and remove the wireless security and see if you can now detect
You will need to check the wireless settings of the router is there any computer connected to the router ? If yes then you can open the router set up page on that computer. Router set up page is the page where you can check all the wireless settings of the router. Click here for step by step instructions
Yes ! the wireless network name could be different than the wired network name. If you connect the cable to the router and the computer it works . check the wireless settings of the router. Click Here for step by step solutions
-- who is your internet service provider -- what is the operating system of your computer? -- are you using a wired or wireless computer in configuring the router?
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer. Step 2: reset the router while power on then Unplug the router’s power cable. Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds. Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable. Step 5: Plug in the router's power cable once the modem’s lights appear stable. Step 6: Power on the computer on and configure the router settings Step 7: test the Internet connection.
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
Are you connected to the wireless router with an ethernet cable? Generally, you want to hook it up this way first so you can configure it. If you are hooked up with a cable open your web browser and type in the following address: 192.168.1.1 this should get you to the router's web page. The default login for linksys is username: blank, password: admin
See if you can connect to the router in this way. If you can then we can go through the next steps or you can try using the above link.
