You can have failing power supply due to bad caps.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP and other monitors to get some ideas of what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further, it will also help out other people with the same problem.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Other possibilities: http://www.fixya.com/support/t3240823-ba...
