I am not sure if the drivers exist. The Graphics card seems old and the last Microsoft OS supported were Windows 2000 and XP. I dont own the card but I believe if you ever installed Windows 7 with the card above installed, you gonna end up with a Microsoft generic driver either from the OS itself or from Microsoft update site. Although that I dont think it is supported on Windows 7, but I would still suggest that you check Nvidia website for Windows 7 drivers for this Nvidia Graphics Chip/Card: GeForce 4 MX460. See if they are available and have them downloaded and set. If they worked, good, but if not, remove them. Please make sure you download the driver needed whether it was a 32 or 64bit referring to your OS installed. Good luck.
Default is 0000. If you have further problems, you can do a factory reset. WARNING: This will format the device, wiping all data off. This will cause you to lose everything on the device. To do a Factory reset:
Jog Dial UP * Jog Dial DOWN Jog Dial DOWN * Jog Dial DOWN *
Explanation: With the phone on, move the side/jog dial upwards once ,
then press *, move jog dial down twice and press * again, move jog dial
downwards and press *
You will then see "Service Menus" and can choose either "Service Information" "Service Tests" or "Format Internal Disk"
Canopus has not releases a driver for this capture device. Their product guidelines indicate that no driver is needed for Windows XP - but there is a known issue with OEM versions of XP that causes it not to work. Their own tech support advises a complete reinstallation of Windows. Sorry!
Try resetting the Walkman by pressing the RESET button located near the Jog Dial.
Press the reset button using a sharp pointed object like a ball pen. Be sure that the Walkman is playing when resetting.
Try connecting the Walkman Player to the Computer by using the stand to charge the battery and check if it works normally.
If the issue persists after resetting, try Formatting the Player back to factory defaults. Formatting the Player will erase all the files and all the settings will be back to factory default. Please be sure that a backup is there with you before formatting the player.
To Format the Player, unite the left and right parts to turn off the Player. Separate the left and right parts.
Press and hold the jog dial for about 15 seconds until the status lamp blinks quickly.
Release the jog lamp when the OPR Lamp lights Red.
Rotate the jog dial within 30 seconds after the OPR lamp lights Red.
The status lamp turns off and the OPR Lamp lights alternately Green and Red each time you rotate the jog dial.
Press the jog dial while the OPR Lamp lights Green.
The OPR Lamp blinks Green quickly and Formatting is executed.
When the OPR Lamp turns off, formatting is complete.
If you press the jog dial while the OPR Lamp lights Red, or if 30 seconds have passed, formatting will be canceled.
This will resolve the issue.
just try this.. enter service menu by pressing jog dial up, *, jog dial down, jog dial down, *, jog dial down, *.
jog dial is rounded things at the right side of the p1, slide it up or down, follow the instruction.
then enter the menu hardware test, lcd test, write something in ur touch pad, if the letter u wrote visible it mean ur lcd fine.. so , just close the menu and its magic.... its worked.
1) Press "Program" 2) Turn "jog dial" up until "DATE TIME! appears on the display 3) Press Jog Button 4) Enter settings by pressing dialing keys 5) Press jog button and set other parameters on the display ( step 3 - 4)
6) After last you will hear a long confirmation beep
Hi it's better formatting the internal disk instead of the master reset. The way to do that is entering the Service Menu (Jog Dial Up/ Press * / Jog Dial Down / Jog Dial Down / Press * /Jog Dial Down/ Press *) and choose "Format Internal Disk".
REMEMBER THAT ALL YOUR INSTALLED APPZ AND SETTINGS WILL BE LOST (the phone turns in factory defaults settings)
Did you check the settings with the applet for "Tablet and buttons" (from the control panel)? Did you install anything recently or make any other system changes? Perhaps a rollback (system recovery) might fix the problem. This works the majority of the time.
dont give up...it may take three or four restore attemps before you find one that works..pick a recent date from when it was working correctly and restore to then, if it doesnt work go back a few days earlier.
