LG L1717S-BN 17" LCD Monitor Logo
Posted on Mar 13, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MONITOR SWITCHES ITS SELF OFF
FELLAS, I HAVE A PROBLEM WITH MY LG MONITOR WHEN I TURN IT ON IT IT TURNS ITS SELF OFF WITH IN A FEW SECONDS.
I HAVE CHANGED BOTH THE POWER CABLE AND THE VGA CABLE WITH NO RESULTS.0 THE PROBLEM REMAINS THE SAME.
ANY IDEA'S, COULD DO WITH SOME HELP ON THIS ONE. THANKS VERY MUCH. JJ
Anonymous
Level 2:
Novelist:
  • Expert 138 Answers
  • Posted on Mar 14, 2008
Anonymous
Expert
Level 2:
Novelist:
Answers
138
Questions
Helped
399842
Points
233
Hi this is the way how to examine what's wrong with your LCD monitors. Power on both CPU and monitor. After it turns itself off, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. I used to check my LCD monitor and could see window image using flashlight and found out that Some of CCFL lamps inside were broken. The lamps are very easily replaced. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Thank you,
Tan
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 25, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
239
Points
LG FLATRON L1717s Blinking GREEN LIGHT Till 10mins Whenever i am turning on my CPU with the monitor, my monitor won't turn on. I need to wait for 5-10mins for my monitor to Turn-On. And if i turned off my monitor and turn-on again, i have to wait for 10mins again.
2answers
My LG tv will go on then after a few seconds the screen goes from black back to picture of and on a few times then shuts off. Help!
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
7 days ago - My 32' LG LED TV has suddenly lost picture! The sound is all right but theScreen is pitch black. After switching it on the picture flashes for a second and thenthe ... LG LED TV has no picture (black screen) but still sound - can it be fixed? Tags: ... a touch on the screen reveals nothing so it's not the back light.
Monitor going black after 2 seconds [Solved] - CCM.net
ccm.net > Forum > Hardware
Oct 9, 2012 - Brightness goes down, display draws less juice, and you can at least use .... it's the LCD's Inverter ... you have to replace it for it to go back to ... If the screen is turning off every two seconds or so and then it comes ... i turn my tv on it comes right on, but then after a few minutes turns off, .... Digital Trends for LG. No display in monitor
Jan 11, 2013
Ps3 and hdmi cable
Oct 8, 2012
More results from ccm.net
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
Dead computer monitor
switch is usually at side just fill it just takes few seconds to turn on / maybe the lcd is not working an more gotta change it
Lg w2234s-bn Monitor Cycling randomly through Light View Modes/Power Button turning It's self on and off.
On and off cycleing could be caused by a bad power supply or a low battery on your remote. Check them both out. Good luck.
The monitor fades to black, a few seconds after I turn the pc on (even before starting windows); the blue button keeps on. When I turn it off, and then turn it on again, it works for a few seconds, then it...
Simplest solution first; check your cables. If the connections are good, but it still doesn't work, try your monitor with another computer. If it works, you need to update the drivers on your computer. If it doesn't, the problem is with the monitor. If your computer needs drivers from LG for the monitor, you need access to another computer (or another monitor to go online). Go to LG's website and look for SUPPORT. Download drivers for your monitor specific to your operating system (Windows, Mac OSX, etc.) and install.
1helpful
PC boots for seconds then NOTHING APPEARS SCREEN
Check to see if you have inadvertently hit the CRT button which turns off your screen to turn on an externally connected screen even if there is no external screen plugged in. OR you could have a bad (Back-light) or (Inverter)
5helpful
HP 1940 goes blank After 3 Seconds. after turning on this monitor it goes blank if i turn it off then on again it will display the comptuer output again but then turn off after a few seconds. any hints?...
Run a monitor aelf test.... Remove the monitor cable from the back of the tower... and see if it run self test.... also a install the driver for the monitor
TV screen turned on for only 10-15 secs then self turn off, followed soon after by the tv power another 10-15 seconds later. if i try this a few times screen wont light up at all.Is it the TV Lamp?
1) Can be dust do a good clean
2)Check for the fuse and change it if needed.
3) Capacitor needs to be changed, you'll have to findout which one.
Hope it helps, good luck
1helpful
Monitor turns off
If the picture is Reddish either at top or bottom It could be the backlight failing.If you are technically able you maybe able to Replace the CCFL backlight.
Samir
2answers
Lg flatron l1510s
Try hooking the monitor up to another computer to see if the symptom remains the same if it does you might be needing a new monitor
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
