20 Most Recent
LG W2252TQ Monitor Questions & Answers
"Analog going into power saving mode" when I try to play a game.
Most of these kinds of problems are created by using the different version than the current version of your video card driver.
Check your video card company's website and download the specific video card driver for your devide's ID and It should resolve the proble,
Monitor switch always return to Sleeo Mode
You can open the VGA cable and connect it again, sometimes there are two or three vga ports behind your cpu, connect the right one. Try it, if not success, change the cable.
When I turned on my PC this morning, I saw as the
Probably a problem with the OS itself. I would recommend putting in your OS cd (the one that came with the computer. And restart, select the option to repair OS (or says something to that effect). This may fix the problem. If it does not try another monitor, see if it is monitor specific (I dont think so, it sounds like it is an OS problem)
The monitor fades to black, a few seconds after I
Simplest solution first; check your cables. If the connections are good, but it still doesn't work, try your monitor with another computer. If it works, you need to update the drivers on your computer. If it doesn't,
the problem is with the monitor. If your computer needs drivers from LG for the monitor, you need access to another computer (or another monitor to go online). Go to LG's website and look for SUPPORT. Download drivers for your monitor specific to your operating system (Windows, Mac OSX, etc.) and install.
No power
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed LG monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.Please leave rating if it helps.
