I have already changed the display unit as well as the main relay in back of the unit. During the self cleaning mode, the stove stops after 90 minutes, starts beeping and the F7 fault appears. What electronic control is defective?
Thanks
Morty
you may need to replace the main control..
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
The stove im working on does the very same thing , but it does it automaticly and is always on 24/7
