Ovens Logo
Posted on Dec 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
''F7'' Error Code
I attempted to change the time on the clock on my Caloric Prestige Self Cleaning oven but I received a ''F7'' error code and a continuous beep. I turned off the power to the oven but when I turned it back on, the ''F7'' and beeping returned.
Anonymous
Level 3:
  • Master 6,784 Answers
  • Posted on Dec 20, 2009
Anonymous
Master
Level 3:
Answers
6784
Questions
Helped
2971169
Points
24702
HI. This is the result of a failed function key. This is an integrated part of the main control board. Unfortunately, this is not repairable, and the main control board will need to be replaced, asap.
Ge performance profile F7 error code
code f7 is a error code for self cleaning device
3helpful
F11 error code - frigidaire electric overn
Disconnect power for 30 sec, then turn it back on
3answers
I have a Whirlpool Super Capacity 465 self-cleaning oven. I tried to use the Auto Clean function tonight, but after about 15 secs., the oven displayed error code FSE1, beeped multiple times, and then...
I researched your question regarding error code FSE1. I could not find a response regarding a self cleaning oven. If you will provide the model number on the below listed website under "cooking" you may get a detailed response.
http://producthelp.whirlpool.com
It seems that a general "fix" for error codes is to got to your electrical panel and shut off the breaker controlling your device for 1 minute. This resets the device and will reset the error code. (May not fix your issue but will reset code.)
Your manual should have a list of error codes to help you resolve this issue. If you have misplaced the manual, you can also download one for your device from Whirlpool's website as well.
If all else fails here are the U.S. and Canadian telephone numbers under "Contact us". I do not know if this is a pay line or Whirlpool will answer your questions and attempt to resolve at no cost.
US: 1-866-698-2538
Canada: 1-800-807-6777
Jan 02, 2018 • Ovens
7helpful
The oven isn't working and it says FO in red letters
GE / Hotpoint / RCA
Oven Fault Codes
Display Condition Remedy
F0 & F1 Failed Thermistor Control Replace ERC
F2 Oven Temp Exceeds 590 with unlocked door High resistance in Sensor, likely a bad sensor
F3 Open Sensor circuit Open (blown) sensor fuse or bad Sensor
F4 Shorted wire or Sensor locate short and correct it
F7-A Function pad button stuck Clean and unstick
F7-B Bad Clock Replace Clock
F8 Electrical component failure Replace ERC
F9 Program with door circuit Check wiring
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Amana / Caloric
Oven Fault Codes
Type with display - glass link ERC
F0 No Safety Signal Replace adapter board
F1 No Safety Signal Replace ERC
F2 Oven over heat Replace defective Sensor
F7 Shorted Touch Panel Replace Glass Panel
F9 Door Latch Error Check latch
FF Lock Error Check switch and motor
ERC III - Relay board with separate board/push buttons
F0 Shorted Push Pad Replace Push Pad
F1 Defective ERC Replace ERC
F3 Oven Sensor Open Check/Replace Sensor
F5 Defective ERC Replace ERC
F6 Defective ERC Replace ERC
F7 Shorted or sticking button Clean button or replace touch pad
F8 Defective ERC Replace ERC
The following diagnostic chart Does not apply to Whirlpool 'Y' line products. If the model number contains a Y near the end of the number, DO NOT use this chart.
Whirlpool / KitchenAid / Roper
Oven Fault Codes
Ovens with 4 digit displays
F0-E0 Analog to Digital failure Disconnect panel for 30 seconds. if error re-appears then replace control
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Ovens with 2 Digit Displays
F0 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground
F7 Shorted or sticking button Clean button or replace ERC
F9 Door Latch Error Check latch and latch circuit
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 18, 2009 • Ovens
Need owners manual for Caloric prestige series electric stove. self cleaning instructions
prestige cooker with built in oven is suddenly making loud noise .don't know what to do?
Oct 18, 2009 • Ovens
F7 error code
Hi
On a GE range oven F7 indicates either a function pad button is stuck or the clock on the oven is malfunctioning
On the 99 Range oven F7 indicates a shorted Clear/Off Key due to membrane switch or a shorted control or connector
On the GE XL44 Self Clean Oven F7 is Stuck keypad or control relay malfunction
check out more detail here
http://www.fixya.com/howto/h155060-dreaded_f7_error
hope this helps
3helpful
F7 error code- what does this mean?
Oven Fault Codes
After self clean, jtp15 panel does not work
This may be related to the F7 problem. The error does not always show up on the display. It typically develops after a self-clean cycle. Go to my solution at the following link:
I have shared this solution with over 1500 folks and most report success. Let me know if this works for you at:
[email protected]
Top Kenmore Ovens Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
