If your machine is a front loader, then you will need to remove the rear panel, normally this is just a screwdriver requirement. make sure you take your old belt as the supplier will require the numbers from it to ensure you get the correct size. There are many different belts. Place the belt onto motor shaft and then onto drum pully wheel as far as it will go. You then need to rotate the drum by hand to feed the belt onto the wheel. After you have done this you may need to line the belt up by moving it across the grooves on the motor spindle. to do so again move the drum pully around and at same time move belt across the motor pully groves until belt runs central on drum pully. This may seem awkward but you will be suprised how easy it really is.Also it will save you a fortune by doing this yourself
