Machine shows disc error when disc is loaded. Will not play.
You may need to get the discs repaired or it may be your laser in the player need cleaning. Easiest soloution is to basically clean your disc(playside). Check for scratches on both sides of your disc. If the label side is scratched in any way, it might be unrepairable as this is where the data is stored, if the playside is scratched they are repairable. You can try home remedies if the scratches are very slight, if not professional repair is required. Try other discs in your player, if they are not working either, then it may the players laser is dirty and may need a laser cleaner, fairly cheap in some stores.
If it's the disc thats scratched visit www.discREPAIR.ie for FAQs and futher help or disc repairs.
