WCVH6800J1WW GE Washer
How do you make the machine display tell you if there are any error codes.
Almost every load the tub bangs around like the load is not balanced in spin mode
Try to clean the discharge pump filter first (Instructions on page 13 of the Use/Care manual).
If the drain pump is working, it's most likely related to the pressure switch. Check out these postings:
http://www.fixya.com/support/t9807344-ge_front_load_washer_stops_45_min_35_min http://www.fixya.com/support/t8933273-general_electirc_washer_model Do a diagnostic test -- Easy and free, and the machine will likely diagnose its own problem. Instructions in those postings.
Post back any code you find and we'll go from there.
diagnostic
http://hindinewsblog.com/ge-washer-fault...
