Red and green is the phone in and the brown and grey are the phone out thats all u need make sure u connect it to the main line into the building as the pannel needs to have priority on the line
see connection colors below and let me know if you have questions.
2004 Nissan Sentra wire colors aftermarket radio wire colors
Car Radio Constant 12v+ Wire: Pink, yellow
Car Radio Switched 12v+ Wire: Blue, red
Car Radio Ground Wire: Gray, black
Car Radio Illumination Wire: Red/Green, N/A (tape off factory wire)
Car Stereo Dimmer Wire: Red/Yellow, N/A (tape off factory wire)
there is no factory amplifier wire, blue (tape off radio wire)
Left Front Speaker Positive Wire (+): Pink, white
Left Front Speaker Negative Wire (-): Blue, white/black
Right Front Speaker Positive Wire (+): White, gray
Right Front Speaker Negative Wire (-): Black, gray/black
Left Rear Speaker Positive Wire (+): Light Green, green
Left Rear Speaker Negative Wire (-): Violet, green/black
Right Rear Speaker Positive Wire (+): Blue, violet
Right Rear Speaker Negative Wire (-): Pink, violet/black
use at your own risk. I can not confirm these.
+12V DC Battery(Constant)
Yellow/green
31
15 Amp
Fuse box on left front of engine compartment, near battery.
Switched Accessory
Purple
6
10 Amp
Fuse block behind left side of dash
Power Antenna
NCA
Green for antenna signal
Illumination
Red/yellow & red/blue
Steering Wheel Control Wire
Red/white, green, and blue
If equipped, as for Mid-Line.
Left Front +
Blue/white
Left Front -
Blue/red
Right Front +
White/black
Right Front -
Blue/black
Left Rear +
Green/yellow
Left Rear -
Black/yellow
Right Rear +
Blue
Right Rear -
Red
AT SPEAKERS
Wire Function
Color
Note
Left Front Tweeter +
Blue/white
Left Front Tweeter -
Blue/red
Right Front Tweeter +
White/black
Right Front Tweeter -
Blue/black
left to right black red green yellow only two wire operate a phone red and green for one line and black and yellow for the other line so you can run two line down one phone cable as long as red and green are in the center.
1990-92 Eagle Talon Stereo Wiring
Constant 12V+
Red/Black
Switched 12V+
Blue
Ground
Chassis
Illumination
Green/White
Dimmer
Black/Yellow
Antenna Trigger
White/Black
Antenna
Left Rear
Front Speakers
4" Dash
Left Front (+)
White/Blue
Left Front (-)
Black/Blue
Right Front (+)
White/Red
Right Front (-)
Black/Red
Rear Speakers
6 1/2" Side Panels
Left Rear (+)
Yellow/Blue
Left Rear (-)
Gray/Blue
Right Rear (+)
Yellow/Red
Right Rear (-)
Gray/Red
yellow battery red accessory black ground purple right rear + speaker purple/black right rear - green left rear + green/black left rear - white fr left + white/black fr left - grey fr right + grey/black fr right - blue auto antenna blue/white rem amp brown phone mute orange/white illumination
yellow to yellow main power wire red to red key wire black to black ground speaker wires are green purple for rear speakers and white and grey for front speakers solid wire color is power and black lines is ground orange is dimmer switch you wont need it blue wire is for power anntenna your car shouldn't have it and blue with white stripe is remote wire if you have an amp it will shut off your amp when hooked up any other wire unnessary for your car some head units need a anntenna adapter to work good luck. remember ground before anything and disconnect the battery so you don't blow the fuse
Hello uze7, Here is the wiring match up for a 2009 Subaru Forester using the Metra 70-7552 wiring harness: NOTE: The actual harness will be listed as a Nissan harness, but has been used by Subaru since 2007. Also, I'm assuming that your Sony deck uses the standard color code. If not, you should have a manual that lists the function along with the colors. Match the wiring by function, not by color (although the colors may be the same). 2009 Subaru Forester Radio Wiring Color Code: Battery BLUE/RED (+) RADIO HARNESS Accessory YELLOW/RED (+) RADIO HARNESS Ground BLACK (-) RADIO HARNESS Illumination VIOLET (+) RADIO HARNESS Dimmer BLACK/WHITE (-) RADIO HARNESS Power Antenna YELLOW/BLACK (+) RADIO HARNESS LF Speaker (+) BROWN LF Speaker (-) BROWN/WHITE RF Speaker (+) BLUE/WHITE RF Speaker (-) BLUE/YELLOW LR Speaker (+) WHITE/BLACK LR Speaker (-) RED/YELLOW RR Speaker (+) GRAY RR Speaker (-) GRAY/RED Metra Harness: Yellow ? 12V Constant Red ? 12V Accessory Black - Ground Orange ? Dash Light Dimmer/Illumination Green ? Left Rear Speaker (+) Green/Black - Left Rear Speaker (-) White ? Left Front Speaker (+) White/Black ? Left Front Speaker (-) Purple ? Right Rear Speaker (+) Purple/Black - Right Rear Speaker (-) Gray ? Right Front Speaker (+) Gray/Black - Right Front Speaker (-) Standard CEA Color Code: Blue - Power Antenna Blue/White - Remote Turn-on Pink/Black - Audio Interrupt In (Phone) Orange - Illumination Red - Ignition (Switched 12V) Yellow - Battery (Constant 12V) Black - Ground Gray - Right Front Speaker (+) Gray/Black - Right Front Speaker (-) White - Left Front Speaker (+) White/Black -Left Front Speaker (-) Violet - Right Rear Speaker (+) Violet/Black - Right Rear Speaker (-) Green - Left Rear Speaker (+) Green/Black - Left Rear Speaker (-) Hope this helps.
Orange is for illumination and connects to the "dimmer" wire on your vehicle wiring. Yellow/Black is the mute lead and connects to your bluetooth or hardwired audio mute function. Blue/White (terminated with a quick disconnect) is the remote wire and provides a 12V positive turn-on signal for a power antenna or remote amplifier. Speaker wiring follows the industry standard color code:
White - left front +
White/Black left front -
Gray - right front +
Gray/Black - right front -
Green - left rear +
Green/Black left rear -
Violet - right rear +
Violet/Black - right rear -
If you do not have a copy of the installation/user manual, you can download a copy from Crutchfield. It will have the complete wiring diagram and color codes as well as operating instructions.
on what system?
