Question about Car Audio & Video
Suburu radio wire harness. trying to match up with a new soni deck
Posted by uze7 on
Ronny Brite
  • 655 Answers
Hello uze7, Here is the wiring match up for a 2009 Subaru Forester using the Metra 70-7552 wiring harness: NOTE: The actual harness will be listed as a Nissan harness, but has been used by Subaru since 2007. Also, I'm assuming that your Sony deck uses the standard color code. If not, you should have a manual that lists the function along with the colors. Match the wiring by function, not by color (although the colors may be the same). 2009 Subaru Forester Radio Wiring Color Code: Battery BLUE/RED (+) RADIO HARNESS Accessory YELLOW/RED (+) RADIO HARNESS Ground BLACK (-) RADIO HARNESS Illumination VIOLET (+) RADIO HARNESS Dimmer BLACK/WHITE (-) RADIO HARNESS Power Antenna YELLOW/BLACK (+) RADIO HARNESS LF Speaker (+) BROWN LF Speaker (-) BROWN/WHITE RF Speaker (+) BLUE/WHITE RF Speaker (-) BLUE/YELLOW LR Speaker (+) WHITE/BLACK LR Speaker (-) RED/YELLOW RR Speaker (+) GRAY RR Speaker (-) GRAY/RED Metra Harness: Yellow ? 12V Constant Red ? 12V Accessory Black - Ground Orange ? Dash Light Dimmer/Illumination Green ? Left Rear Speaker (+) Green/Black - Left Rear Speaker (-) White ? Left Front Speaker (+) White/Black ? Left Front Speaker (-) Purple ? Right Rear Speaker (+) Purple/Black - Right Rear Speaker (-) Gray ? Right Front Speaker (+) Gray/Black - Right Front Speaker (-) Standard CEA Color Code: Blue - Power Antenna Blue/White - Remote Turn-on Pink/Black - Audio Interrupt In (Phone) Orange - Illumination Red - Ignition (Switched 12V) Yellow - Battery (Constant 12V) Black - Ground Gray - Right Front Speaker (+) Gray/Black - Right Front Speaker (-) White - Left Front Speaker (+) White/Black -Left Front Speaker (-) Violet - Right Rear Speaker (+) Violet/Black - Right Rear Speaker (-) Green - Left Rear Speaker (+) Green/Black - Left Rear Speaker (-) Hope this helps.
Posted on Aug 14, 2009
I just replaced my 2003 chrysler town and country with a 2007 town and country. I want to put the old radio /cd deck into the new one. Is it just as easy as switching part for part, without adding any...
It depends if they have matching numbers or not. their should be no wireing harness needed only wiring harness needed if replacing with after market radio
Oct 10, 2011 | 2001 Chrysler Town & Country
I have a 98 grand prix an I was wondering how to install it.. I have a harness that came with it but my factory harness won't fit. I was wondering if j have to rewire the factory harness to my JVC...
You need to go to your local "best buy" or electronics store and ask them for your car's "stereo wire harness". This will convert the wires from your car to match all the colors from your deck. (green, purple, white, gray, blue, yellow, red, ect. Same on all after market decks. All brands use the same wires) Take that new harness and your deck harness, twist the matching wire colors together, tape them with electrical tape, plug the harness back into the car and deck, and it should be good. Click, click, done. Remember to plug the antenna in as well before you get the deck in.
Jun 05, 2011 | 1998 Pontiac Grand Prix
I lost the manual to install my stereo pioneer DEH - 23ub
go to store that sells car decks and look for a wiring harness for ur car its about $7 mybe and prettymuch match the colors on ur deck to the harness and then pull ur old deck out and pull the harness from the back the back of that deck and plug that into the wire harness u just bought and hook up the antenna for radio andput the deck into the dash the wire harness should also come with so directions too just in case
Apr 16, 2011 | Pioneer DEH-P2900MP CD Receiver...
I dont hAVE THE wire hardness for my deck and wondering if am able to get just that part
http://www.shopping.com/Clarion-VRX485VD-wire-harness/products?CLT=SCH
The ones i see listed are not an exact model number match, however, in my experience have found that most harnesses will fit models from the same make... for example, when you swap a Sony deck you can replace it with another Sony deck with a different model number just by unplugging the harness from the deck itself and plugging it into the new deck.
Jan 06, 2011 | Clarion VRX485VD Car DVD Player
Whats the proper way to install the cd player into a 1992 chevy pick up truck and if u cud send a manuel
The proper way to install any aftermarket deck into a newer vehicle is to get a factory wiring harness adapter. This adapter will attach to the existing wiring harness for your factory stereo system. You can purchase these from various websites like this http://us.ebid.net/for-sale/1992-chevy-pickup-fullsize-radio-wire-harness-92-17373248.htm?from=googlebase
When you plug this in your factory speakers and power/ground will all be available to wire to your new deck without cutting or splicing any wires. The colors follow the E.I.A standard and should match your new stereo. I hope this is helpful and thanks for using FixYa.
Sep 17, 2010 | Car Audio & Video
CDX-RA700 CD Player: My wires on my sony CDX-RA700 do not match my 2005...
The following should help you. Good luck. Please rate. Radio 12v orange + radio harness Radio Ground black/orange - radio harness Radio Ignition yellow + radio harness Radio Illumination brown/white + radio harness Factory Amp Turn-on lt. green + radio harness Power Antenna gray + radio harness LF Speaker +/- tan - black +,- radio harness Notes: If equipped, the amplifier is in the passenger side of the trunk. RF Speaker +/- blue - red +,- radio harness LR Speaker +/- white - brown +,- radio harness RR Speaker +/- orange - green +,- radio harness
For the stereo the following will work.
May 07, 2010 | Sony CDX-RA700 CD Player
I am trying to wire a sony xplod deck to my 2001 altima and need to know which wires connect to each other and steps of doing that.
Hello charlieramir,
The wiring color code for the 2001 Altima can be found here. Your Sony deck should have come with a wiring harness and an installation sheet (or a page in the user manual) that shows the color and function of each wire. You simply match up the functions of each wire on the harness with the appropriate wire on your vehicle.
A simpler and more professional installation is achieved by using a vehicle-specific wiring harness that plug into your Altima's wiring. Such a wiring harness allows you to make all of the connections while seated at the dining room table or other well-lighted location instead of the limited space area behind the dash. The Scosche NN03B/NN03 seems to be the correct harness for your Altima.
Hope this helps.
Jul 02, 2009 | Sony Car Audio & Video
I want to take out factory radio to install stereo
Stereo dealers have wire harness adapters for almost every make and model of car. It will come with a connector both with color coded pigtails that are usually prestripped. The package will described which wires go where and their color codes. The deck you bought should have a pigtail with color coded wires and they'll match up to the ones on the harness adapter for your car.
After connecting them all properly, you can take your deck with the attached pigtail and plug adapter and plug it directly into your car stereo plug where your old radio was connected...don't forget the anntenna lead as well... Not to difficult...email if you get stuck...
KEN
May 08, 2009 | Sony Car Audio & Video
Audio wiring problem
Radio Constant 12V+ Wire: White/Green
Radio Switched 12V+ Wire: White/Red
Radio Ground Wire: Black
Radio Illumination Wire: n/a
Radio Dimmer Wire: Red/Black
Radio Antenna Trigger Wire: n/a
Radio Antenna Location: Rear Glass
Front Speakers Size and Location: 6 1/2′ Doors
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speakers Size and Location: 6′ x 9′ Rear Deck
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Apr 05, 2009 | 1998 Honda Accord
I am having trouble trying to install a stereo to my 1994 lincoln town car because i dont now the color code to the radio harnes so i can install it
Best thing to do is purchase a Radio Wiring Harness. These can be purchased at a Store like Circuit City, Best Buy, WalMart (not sure of your location) or a 12 Volt Specialty shop.
This harness will connect to your new radio harness and plug directly into the vehicle harness without having to cut wires. The Radio Wiring Harness will come with color identification to match to your radio harness.
FYI http://www.installdr.com/QuickWiring.html
Jan 12, 2008 | Car Audio & Video
Car Audio & Video Logo
430 people viewed this question
Top Car Audio & Video Experts
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
