Hi, This information would be available in the User Guide. Have you checked the User Guide? Thanks!!Hi, This information would be available in the User Guide. Have you checked the User Guide? Thanks!!
You can't post conmments that contain an email address.
to change the date and time you will press F2/F4 at same time, enter password 1 alpha alpha ( key located above 2 key) 66831 enter, then select the purple key to the far left, until you see clock, press the F key corresponding with clock update the date and time and press restart, this will change the time in terminal. remember to use military time.
also you will have to change for day light savings each time it changes.
battery is located inside the machine. You need to open the plastic case to see it. 7 screws holding the case together, but be careful not to break the case, multiple sensors inside the unit, don't loose it. If you still needs help, call us at (775) 358-2922 ask for Randy. http://freshpoint.org
there's different places you can buy parts for this units all depend what parts you need I know a couple of places you can get parts let me know and I will send you the links : - )
The "RTC chip" is an integrated circuit that provides the R(eal) T(ime) C(lock) functionality. If your device cannot keep the correct date & time, it's time to replace it.
To reboot, turn the device off, and then remove the battery.
Wait 60 seconds, reinsert the battery, and turn the device on.
I'm not an expert with that model, but try this link: http://www.semicron.com/omni-3700.pdf (you may have to cut and paste it into your browser's address bar). Go to page 7 and look under the EDIT funciton. I think that's what you're looking for.
Simultaneously press [F2] & [F4].Key in 1, Alpha, Alpha, 66831 and press [Enter].Key in the Year, the Month and the Day and then press [Enter]. Do not press [Enter] between these values, the terminal will automatically populate the appropriate fields as they are entered. Use the down arrow to scroll down to check/adjust the time.y in the hour, using military format (ex: 3 p.m. = 15), then key in the minutes and press [Enter] to complete and return to Menu 1. Do not press [Enter] between these values, the terminal will automatically populate the appropriate fields as they are entered.Select Restart [F4].I hope this help don't forget to rate this post : - )
