If a read head burns out or the alignment has changed, the laser is inoperative. If a CD/DVD was a copy or reproduced on a computer it too may not be read. If the medium works on other devices, then the players laser may be defective.
Hello; There are many laws and rules controlling what you can watch on all DVD players, built into a TV or separate player. If you go buy an MGM or other dvd of some movie at Walmart , Best Buy ETC it should play in your DVD player, But if You or somebody " Burned a DVD" , It Likely won't play. If The DVD is an original store copy and still won't play, the DVD chassis must be replaced. BIG BUCKS. Just buy a Cheap DVD player and plug into the jacks on the back of the TV and save a TON of money. John
When you insert the disc what does the recorder display after it examines it (Reading TOC)? - CDR, TOC, CDR-W, NO TOC?
It should know the disc is not finalized and let you either record more on it or finalize it.
If not, and you need to recover the 4 tracks try loading the disc on a DVD player. My old Pioneer will read unfinalized CDR-A's so I can digitally copy what's on them back to another CDR-A.
C13 read error means that the player is unable to read the TOC (Table Of Contents) on the minidisc. it has to read this first so that it knows where everything is stored on the minidisc.
TOC errors can be caused by faulty minidiscs, those which have been incorrectly finalised or by a faulty head assembly on the machine.
If possible, try to see if you get the same problem with different brands of minidisc, and also whether minidiscs recorded on other machines work on your player and whether minidiscs recorded on yours work in other players. Report back with what you find as it helps determine whether the player itself is at fault.
In reality though, it's a 9 year old unit and like all optical disc devices, minidisc heads do not last forever. If the head has failed then your only fix is to replace the player as spare parts are no longer in production and existing stocks are almost as rare as fresh dodo doo-doos.
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
Buy a cd cleaner kit, if it doesn't work have some one capable re-align you laser len. When the unit get use for times the len got tired(worn and mis-align). Goodluck.
I am a hardcore video watcher (that does not sound right -- I watch video's everyday -- get your mind out of the gutter). Personally I prefer TCMP player over MM player. I do not use PocketDivx as I usually watch programs capture from a TV card or “obtained” over the internet. I do reformat with Virtualdub.
