This just happened to my L7 10" sux.iIshouldn't use like a silicone type glue?This just happened to my L7 10" sux.iIshouldn't use like a silicone type glue?
You can't post conmments that contain an email address.
Depends on how you blew them and how old they are if they are within a year you can try to write to the company and see if they will fix them if its just the rubber surround then its an easy fix hot glue it or gorilla glue let it dry and hook em back up
is your subwoofer self amplified? if it has, you can connect it through audio sub output and in put to your self amplified subwoofer.. if it is not self amplified, you can still connect it but be sure it ca drive your subwoofer, it depends on RMS or watts of the original sub of the srround..or you can have a seperate amplifier only for your subwoofer. "Audio out - Audio in"
might be your wires inside the box. My brothers does the same thing on deep notes, took the sub out and shorten the wires and seem to stop that noise or kinda rattling sound. I had two 12's the same ones you got, the noise i had was my 12's blowing the box apart lol. Don't hurt to check your box every now and again. hope this was helpful
From what I've gathered lately, audiobahn has gone out of business. You will likely have to go to a speaker shop that specializes in repair. Unless your sub is worth more then 200 dollars or so- your probably better off replacing it.
is the rubber surround blown out.. look at voice coil itself .. it could be repaired but maybe not worth it. can u actuate the speaker down and up.. if you can then the voice coil is fused.. and if u can and u hear or feel resistance then there is work to be done to the voice coil and spider. Could be costly.. if its just the rubber.. use silicone to re-seal it.. ol skool trick..
Sounds like you have shorted output transistors or IC'S There is one test is to disconnect all the speakers and see if they still blow. If they do then you need to have the amp fixed or replaced. If they dont blow try connecting up each speaker till the unit blows the fuse asjust maybe you blew out a crossover or a speaker or two?? If you have an active type crossover then I would check that device as well. Good Luck
