Question about AudioBahn Car Audio & Video
How to wire up an audiobahn aw1251t i want to invert it
Posted by csm31014 on
fred j
    Scholar:
  • 127 Answers
Two 4 ohm Dual Voice Coil (DVC) Speakers Option 1 (parallel/parallel) = 1 ohm load
Voice coils wired in parallel, speakers wired in parallel
Recommended Amplifier: Stable at 1 ohm mono how to wire up an - 2_4ohm_dvc_1ohm.gif
Option 2 (series/parallel) = 4 ohm load
Voice coils wired in series, speakers wired in parallel
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono
have any more question let me know
http://www.tintingbyfredjohnson.com
Posted on Dec 23, 2010
1 Related Answer
uge44
Eugene Tetlow
  • 226 Answers
SOURCE: i dont know which wires
I used to have exactly the same subwoofer. It has dual voice coils which are driven independently.
Hope the diagrams help out. Just make sure you know how many ohms your amp is.
Wiring Option #1
Wiring Option #2
Posted on Nov 20, 2008
I have a audiobahn aw1251t 12 inch sub and punch 1000-1db amp how would i wire it up
as your sub is only rated to 400w rms simply connect the sub to either a or b channel outputs you may wish to use an rca splitter before the amp to feed both left and right audio channels into a single channel on the amp. WARNING connecting both channels on the amp to the sub will overload the sub and possibly blow it up so i highly recommend not doing so.
Mar 17, 2017 | AudioBahn Car Audio & Video
I have a 2 ohm stable watt amplifier with 2 audiobahn aw1251t wiring dual 4 ohm subwoofers, but theres no thump coming from the subs when i have it hooked up. Im sure the problem is the wiring inside the...
Generally there are 2 parts to this problem
part 1
input signal as these woofers are just subs remember to give them a low line in signal before the amp (see diagram) i like to use rca low pass crossover filters from harrison labs (see link)
part 2
is the wiring configuration of the 2 woofers by wiring them in parallel as shown in the diagram you reduce them to a 2 ohm load for your 2 ohm amp meaning you'll get max loudness and efficiency
Harrison Labs FMOD Inline Crossover Pair 100 Hz Low Pass RCA Shipping is...
Oct 28, 2017 | AudioBahn Car Audio & Video
AW1251T WoofersThese Speakers Keep Burning My Amp
You are going to need a multimeter and test the impedance rating on the subs (ohms) if they are frozen or blown they will short your amp. Be careful as your amp will not handle this abuse long.
Apr 08, 2010 | AudioBahn AW1251 Car Subwoofer
Audiobahn a8002t schematic
audiobahn.com under tech support you can download your manual for almost any thing even shows you wiring diagrams helped me out...
Mar 01, 2010 | AudioBahn A8002T Car Audio Amplifier
I need wiring diagram for audiobahn AWES12P 4ohm speaker
you can go to audiobahns website. just fill in the specs like how many subs you have and what kind of amp/amps and it will give you all available wiring options.
Jan 26, 2009 | AudioBahn AW800 Car Subwoofer
I dont know which wires go where on the back of my sub woofer. its an audiobahn aw1251t woofer, 400 watts
Wiring Option #1
Wiring Option #2
Nov 20, 2008 | AudioBahn Car Audio & Video
Wiring subs
audiobahn.com can help you with the free diagrams under tect support
May 03, 2008 | AudioBahn A4075HCQ Car Audio Amplifier
Wiring
audiobahn.com under tect support you can download manuals and get wiring diagrams for free
Mar 06, 2008 | AudioBahn A2801Q Car Audio Amplifier
AUDIOBAHN A3351 WIRING HARNESS
you have to find one that somebody has audiobahn dosnt carry them any more i called them today for mine but no luck
Oct 30, 2007 | AudioBahn A3351 CD Player
Car Audio & Video Logo
Top AudioBahn Car Audio & Video Experts
xxxxxx xxx
ADMIN Canada
ADMIN Canada
ray gallant
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
