20 Most Recent AudioBahn AW1206T Car Subwoofer Questions & Answers
You can use this speaker in either a ported or sealed box. A sealed box would be smaller, (sealed box volume: 0.5 to 1.25 cubic feet) the larger the box the more base you will get. With a sealed box your amp has to work double hard as it would in a ported box ( 1.3 to 3.2 cubic feet) You will get close to double the volume in a ported box. Tuning a ported box with the size and length of the port will determine the hertz the speaker will play at.
AudioBahn... | Answered on Sep 16, 2014
Yes audiobahn do make a QUAD coil, and some people get confused with the - - + + on the terminal, This is called a dual lug, Check out Audiobahn.com and go to tech suport. Thier you can look up the wiring diagram for this sub... TRUST ME hope this was helpful positive feed back be nice lol
AudioBahn... | Answered on Jul 28, 2014
hi there, do you have an amplifier to hook it upto mate? if you do its best to go into your local halfords etc and ask for a wiring kit for you car audio, or search on ebay, theyre normally around 20pounds. then it will come with instructions on where certain wires go etc, the 8 outputs are probably so you can connect two subs together. they should have a pos and neg on them somewhere. if you dont have an amp you probably need to buy one. if you have any further queries just ask mate
If there is one This information should help you find it.
AudioBahn Inc.
AudioBahn... | Answered on Jun 23, 2011
This could be caused due to the impedance load being to low. Your amp is stable to 2 ohm load however its very possible that you have your subs wired to a 1 ohm load that would cause the amp to go into protect mode. The subs you have are dual 4 ohm voice coils and would need to be wired in series/parallel. I've included a link that will show you how the subs should be wired.
http://a248.e.akamai.net/pix.crutchfield.com/ca/learningcenter/car/subwoofer_wiring/2-DVC-4-ohm-mono-low-imp.jpg
AudioBahn... | Answered on May 16, 2011
Are you hooking it up to an appropriate power source? Are you hooking up the power to the power and the ground to the ground, Is the speaker in a box or car panel, if so you may need to take it out to look at the outlets built onto the outside of the speaker to make sure they are not damaged or broken. Other then that the only other thing you can really check is if the bottom of the speaker is still magnetic. If there are any cracks on the actual speaker and when you lightly push it in do you get an audible bump sound.
AudioBahn... | Answered on Feb 07, 2011
if you cracked the giant magnet its a gonner
AudioBahn... | Answered on Jun 11, 2010
Audiobahn is no longer in bidniz sorry to tell you
AudioBahn... | Answered on May 26, 2010
i was just in AUDIOBAHN.COM website yes it's still thier check it out agian
AudioBahn... | Answered on May 17, 2010
might be your wires inside the box. My brothers does the same thing on deep notes, took the sub out and shorten the wires and seem to stop that noise or kinda rattling sound. I had two 12's the same ones you got, the noise i had was my 12's blowing the box apart lol. Don't hurt to check your box every now and again. hope this was helpful
check out audiobahn.com and click on the tech support. then you while see some diagrams for subs, for different ways check it out it helped me out with my aw1508x being pushed by two a2300hcx
AudioBahn... | Answered on May 11, 2010
Hey sound like your amp is seeing to low of indapendece. 3 subs can be hard to wire. please give mre info on the amp and the subs? dual v/c 4ohm subs are 2ohms wired pos to pos. neg to neg.
AudioBahn... | Answered on Jan 19, 2010
crutch feild has a great wiring diagram section. www.crutchfield.com
AudioBahn... | Answered on Oct 14, 2009
Do you mean the voice coil is fried? Well, as it seems that you do not know how to do it, don't attempt. You need special coil winding macinary, and most importantly knowlage of voice coils. Its not just wind the coil. I'd get a professional, because its a lot more then just rewinding a coil
AudioBahn... | Answered on Oct 11, 2009
Audiobahn is no longer in business.
Please describe what you are trying to wire up, and I can help you out.
Thanks!!
AudioBahn... | Answered on Sep 03, 2009
If you have a subwoofer that illuminates - there will be an extra set of terminals on the basket.
This requires a seperate set of power and ground wires along with a toggle switch.
If you want to - you can put the ground on the amplifier's ground, power off the amplifier's power (to a spdt relay) and have the relay activated with the remote wire terminal on the amplifier.
This way it will turn on and off with your stereo system and you wont come out in the morning to a drained battery from forgetting to turn it off.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
AudioBahn... | Answered on Jul 31, 2009
It is a audiobaun. Get rid of it. :-)
AudioBahn... | Answered on Jun 01, 2009
AudioBahn AW1206T Car Subwoofer Logo
Popular Tags
34 questions posted
Top AudioBahn Car Audio & Video Experts
Dalynn Turner
Mike Duncan
Mike Duncan
matthew walsh
Level 1 Expert
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • AudioBahn Car Audio & Video
Most Popular Question
two audiobahn aw1206t
  • Car Audio & Video
