20 Most Recent AudioBahn A8002T Car Audio Amplifier Questions & Answers
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. D .A thumbs up would be greatly appreciated if this answer is helpful to you. audiobahn-a8002t-amplifier-in-protection-lv2kkrmxrai4iihdvw4m3np2-2-0.jpg
AudioBahn A8002T... | Answered on Dec 18, 2014
if the protection light is on an everything is hooked up correct then its got to be on the inside of the amp
AudioBahn A8002T... | Answered on Jul 18, 2011
yes it can be replaced, although you will need a steady hand and a fine soldering iron tip. first if the unit is still under warenty, any "tampering" by yourself will void it. if the unit is under waranty i would take it to a registered repairer.
If it is not, or you are not fussed with voiding it, then after you remove the outer case you will find the faulty componant fairly easy. (make sure there is no power and that it has been at least ten min) so as to avoid any residual charge. then after locating the faulty part, make sure you remove all solder connecting it very carefully, then replace with a like part or one that you would like to fit, paying VERY close attention to making sure that you do not cross any solder over the circuit board as you will cross circuits potentially causing fatal damage to the unit. after that has been done you will be able to refit the cover.
(please note: if it is a later model amp, then it will have LED's not a neon globe.(will not change the procedure, just have to be a little more careful))
kind regards
AudioBahn A8002T... | Answered on Jan 12, 2011
to much power hooked up to it take something away
AudioBahn A8002T... | Answered on Jul 27, 2010
That indicates a short. Either inside the amp or the speaker wires or the speaker themselves are short. Remove the speaker connection if it is still in protection mode then you have an internal short. You can reset these they are there to prevent electrical fire. The only solution is to find the short and fix it.
AudioBahn A8002T... | Answered on May 13, 2010
ebay is a good place to start
AudioBahn A8002T... | Answered on May 11, 2010
audiobahn.com under tech support you can download your manual for almost any thing even shows you wiring diagrams helped me out...
Your fuse to your radio may have blown check that out.
AudioBahn A8002T... | Answered on Sep 20, 2009
try soldering your wier end
AudioBahn A8002T... | Answered on Sep 05, 2009
send it to manufacturer
You can get this from a good electronic shop or you can oredr it via internet.
AudioBahn A8002T... | Answered on Aug 08, 2009
try the website ampguts
AudioBahn A8002T... | Answered on Jul 15, 2009
try the power wires make sure they r grounded properly or won't work
AudioBahn A8002T... | Answered on Jul 01, 2009
No "fault" lights? If not it HAS to be a connection...whether they look bad or not, Redo them, ground FIRST.
Good Luck
AudioBahn A8002T... | Answered on Jun 21, 2009
very simple run a ground from gnd on amp to a good ground spot on car run 12 volt power cable from back of fuse relay by battery to 12v+ on amp then splice blue wire on back of stereo splice in another wire about seven feet run that to remote on amp then hook up speakers its pretty simple to hook up an amp hope this helps
AudioBahn A8002T... | Answered on May 22, 2009
Check all the wiring. It could be a loose connection since it's intermitent. Really pay attention to the power cable, both the end for the amp and the one that's going to the battery cable.
AudioBahn A8002T... | Answered on Apr 24, 2009
The most common cause for an amp to go into protection is shorted output transistors. To eliminate other possible causes, read through the following page.
Troubleshooting - Amp in Protection
Let me know if you have any other questions.
AudioBahn A8002T... | Answered on Jul 23, 2008
What is your complete system set up?
AudioBahn A8002T... | Answered on Mar 19, 2008
add doide from the battery to the unit, 2 doide should help that.
1 connected to the positive, an 1 connected to the negative. 5-10 amperes is ok. check for the polarity. and try to take off the ground of the unit then try it.
AudioBahn A8002T... | Answered on Jan 18, 2008
AudioBahn A8002T Car Audio Amplifier Logo
Popular Tags
27 questions posted
Top AudioBahn Car Audio & Video Experts
Dalynn Turner
Mike Duncan
Mike Duncan
Professor_V
Professor_V
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • AudioBahn Car Audio & Video
Most Popular Question
amp stuck in protection mode some
  • Car Audio & Video
