Tengo el AOC Tv Monitor L22W861 de 22" , y lo uso tambien como monitor y deseo configurarlo a su más alta Resolución, para eso me faltaria el Driver. Donde ¿Y cómo y donce lo obtengo? y si existe otra manera que debo hacer
SOURCE: help me instal aoc mod.tft19w80ps monitor
yes you first connect monitor then insert cd came with pc wait window will open select vga driver option it will be installed then switch on pc
SOURCE: OSD Lock
SOURCE: I can't find the power cord or the pwr adapter for my AOC A15X2
You should be able to get one from your local electronics supplier, such as **** smith, radioshack or jaycar. You need a power pack which outputs 12VDC with minumum 3.5A (you can use more than 3.5A if you need)
SOURCE: input not supported
screen resolution probably the problem if you have another moniter like a crt(which can support higher resolution) change it to the lowest level resoultion and then put in you lcd moniter and see if it works and if it does change the resolution to a comfortable level for you
