20 Most Recent
AOC MW0811 Breeze 8Inch Tablet PC Black Questions & Answers
Tablet discharging
Probably a faulty motherboard. How old is your tablet?
has it been dropped in water or has water entered it by any means?
Unlock a aoc tablet
You will need to do a factory reset:1. With the device off, press and hold Volume Up and Power.2. Release the Power button when you see the Samsung logo, but continue to hold Volume Up until the recovery screen appears.3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.4. Press Volume Up continue.
Buenas noches, tengo problema con
A mi tambien me salio, no me dejaba entrar a ninguna aplicacion, no lo podia quitar. Tuve que recuperar el sistema operativo para regresar al inicio de fabrica aqui te dice como hacerlo es muy sencillo
http://latin.aoc.com/support/troubleshooting.
Te borra las aplicaciones que tengas instaladas pero lo que tienes guardado en tu memoria se mantiene.
No se como evitarlo para, si alguien puede decirme, tks.
When I run a .mov
Hi
The tablet most likely does not support
the format, a standard format for Mobile Phones is avi, which may work
for the Tablet, do not fear if you can't install applications from the
Market, try searching for whatever you need on 4shared.com.
How to install rom on Onn 100011886 tablet go edition.
"rom"? What exactly are you trying to do? Are you referring to ROM as part of the tablet's memory? If yes, you probably will not be able to do it. ROM is a memory chip built onto the circuit board itself inside the tablet. You would need to completely dismantle the tablet to do it. Most tablets are not built to be taken apart for repairs.
4/13/2024 11:56:23 PM •
Tablets &...
Answered
on Apr 13, 2024
