This is a small bosch compressor for nail guns. it runs but does not build up any pressure. I have had it a couple of years with no problem before now.
you may have to rebuild it again. inspect nail gun piston cylinder to ensure that it is not worn or scratched. Is the gun lubed before each use and periodically under heavy use?. Water from compressed air will damage gun.Use quality parts use buna n o rings not buna o rings
good luck
Sb504000 works just fine with pressure range from 60 to 120 psi depending on material. Any small compressor will work great. Using the gun at max pressure will shorten the life of the gun. Best practice is to set pressure to just under 100psi for most work and increase pressure when nailing hard wood. Using at max pressure will strain the driver and the lower part of gun (screws that hold nose to body). Some hard woods will bend an 18 gauge nail. Good luck with your gun and have fun with your projects.
150 lbs is the amount of pressure in the tank. When you connect a nail gun for instance you cannot nail everything at 150 lbs of pressure, it will blast through. The regulated pressure is at zero because you have the ability to regulate it by turn the know under or beside it to increase the output pressure to your desired amount. I was building a shelf last week and set my regulated to 80lbs with a brad and it blew through the panel and stuck in the floor. After you get to know your nail gun you will be able to regulate it between 60 and 80 depending on the type of wood. Panel - 50 lbs, Oak, 90 lbs, etc. Pleas remember to rate this solution high if it was helpful and explained it to your satisfaction.
A nail gun works on compressed air. When you hook the air hose to the gun it fills a cylinder with air pressure. When you pull the trigger. the cylinder pressure is released onto a firing pin that shoots the nail. The air pressure line is also connected to the trigger and therefore the trigger has to be sealed.
When ever using a nail gun, you add a bit of gun oil in the back of the gun (not 3-in-1motor oil, it has to be non-detergent gun oil)
If you haven't used the gun in a while, it is best to oil up the gun and let the oil run down into the gun. If you use anything but gun oil, the seals will give out.
Your trigger seal has given out. It is probably an 'O' ring. You can access it by taking it apart. Look for the O ring. Bostich makes re-build kits for the different guns that you can buy on-line. Back when I was in construction, there were several nail gun shops that sold and serviced nail guns, and sold nails to the contractors. I don't know if that business model is still active or if you have to send the guns to Bostich service center.
Hi there .
First check if the nail gun have a adjustment screw . Depending on the brand could be in the front where the nails comes out or by the trigger. Second check the compressor by the air hose connection you should have a regulator valve with a gauge and see if you getting the right air pressure .
Hope this help
Your air pressure is dropping everytime you fire. It sound like your compressor is not cutting back in untill it to low. Not giving your tool enough continuess pressure. Your compressor cut in pressure should be around 90-100psi no less. and your max. pressure no more then 120psi. (Make sure your regulator is set at 110psi)
good luck...!
I think you'll have to look at your specs on your nail guns and see what the demand is . Whether measured in cfpm or psi, your compressor will tell you the max output of each of those. Then you divide the maximum sustained output of the compressor,, lets say it is 60 psi. Let's say the guns require 10 psi, 60 divided by 10 is 6 = 6 nail guns. This is completely hypothetical as I have no idea what your nail guns require, only you know what kind of guns you have.If you need to run more guns than the compressor can push air for, you'll have to invest in another compressor, maybe even one larger to handle the guns running wide open consistent nailing. Nothing a drywaller hates more is than for all the cursed clip nails not being drove in all the way, lol, and that's what will happen with insufficient air supply. Matt
A good-quality starter set, including both a compressor and a small nail gun, can be bought for around 200 US dollars (USD). More sophisticated models can reach 1000 USD or more. Optional features such as a hard-shell case, safety trigger, and depth adjustment can drive the price even higher. For one-time jobs, a nail gun can also be rented at hardware stores and home repair centers.
Set up the pressure on the air compressor. First plug the air compressor in, then check the pressure. It should be between 90 and 110 pounds per square inch (PSI) for home use. If it is not in this range, turn the knob to the left to decrease the pressure and to the right to increase the pressure. Use the appropriate nail gun for the job. For example, to nail shoe molding to base boards, a standard finishing nail gun would be perfect. It holds any size nail between 5/8 inch and 2 inches. This nail gun could be used for many projects with great results. Check the gauge the nail gun takes before purchasing the nails for the gun. If you get the wrong gauge they will not fit in the gun. You can check this by looking at the information printed on the side of the nail gun next to the model number. You can also open the nail chamber for this information. Attach the nail gun to the air compressor. You can do this before or after you load the nails into the gun. Use the air compressor hose to attach to the bottom of the nail gun. It screws on much like the end of a hose. If you do not have the right size air hose, you can find one at your local hardware store.
