20 Most Recent
Carrier 42QG24-C / 38QG24-C 24000 BTU SPLIT AIR CONDITIONER FOR 220 VOLTS ONLY Questions & Answers
My car is over heating
check your over-flow bottle & radiator for coolant ( this is the usual round silver cap in front of engine compartment // says DO NOT OPEN WHEN HOT !!!!!!!!! ) if empty ,look for leaks or have pressure tested for leak ------------ also check to see if electric radiator is turning on when it reaches operating temperature , this fan will also run or cycle on & off with the air conditioning on....--- if not check under hood fuse // relay for this circuit......
Compressor stopped working. Air
Check for power out of the contactor...is the condenser fan running?? If so then the compressor should have power...could be the compressor capacitor...or a bad compressor.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
What oil should I use in Handiair H8/25 Compressor?
Many air compressors use a mineral blend or a synthetic oil, such as synthetic hydrocarbon, polyol ester or polyglycol. It is important to use a lubricant specifically rated for air compressors; do not use a general-purpose motor oil used for automotive or other purposes.
Read your user manual for more information.
