SanDisk Sansa Clip MP3 Player Logo
Posted on Feb 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Will or won't i be able to import songs from itunes to my sansa clip, and if not will i atleast be able to download the songs to my pc and then sync them to my sansa. i need to know before i make purchases from them.
Anonymous
Level 3:
Guru:
  • Master 480 Answers
  • Posted on Feb 19, 2010
Anonymous
Master
Level 3:
Guru:
Answers
480
Questions
Helped
122160
Points
1311
Normally with itunes you can.
You can also use windows media player.
Why wont this sync with my itunes library?
Hi, Is the SanDisk Sansa Fuze compatible with iTunes? In some ways, it is. Unfortunately, the Sansa Fuze and iTunes don't always play nice together. You'll have to get a few workarounds to make these two sync together.
The SanDisk Sansa Fuze and iTunes
The SanDisk Sansa Fuze is natively a Windows product. You should be able to sync it with Windows Media Player automatically. However, not everyone owns a Windows PC and even if they do, they might store more music in their iTunes library.
If this is the case for you, you might find it helpful to be able to sync your Sansa Fuze with your iTunes music library. Bear in mind that you won't be able to sync apps, games or any other iTunes products that are not formatted for use on a Sansa Fuze.
Using iTunes with the Sansa Fuze
So, is the SanDisk Sansa Fuze compatible with iTunes? If you download the right software, it is. Apple offers a free download that works with many other non-iPod MP3 players, Sansa Fuze included.
Unfortunately, this product only runs on a Mac operating system. However, if you own a Mac, this is great news because it means you can still use your Fuze without buying a Windows PC.
If you use a Windows PC and want to transfer your iTunes music to the Fuze, don't lose hope - there's a way to do that, too.
Syncing the Sansa Fuze with iTunes
If you're using a Mac, visit this link for Apple's free software download. It comes directly from Apple, so you can be assured that it's spyware-free.
Install the software on your Mac. You need Mac OS X 10.4 or higher as well as iTunes version 8 or higher.
Plug your Sansa Fuze into the Mac and wait for the software to open. You should see a listing of your iTunes music library pop open in a window. You're then given the option to sync as many songs as possible onto your Fuze.
The syncing process is similar to syncing an iPod. Don't unplug the device until it's finished.
Syncing the iTunes Library in Windows
You can sync your Sansa Fuze with iTunes using a script called the Automator, found here. Once downloaded, open the script under your "Downloads" folder on your "C:" drive and find a string of characters that looks like this: "/Users/richard/Music/*.mp3".
Replace the name "Richard" with your own username. Don't change anything else. Select "File," "Save" from the menu.
Select the Automator icon with the right click button on your mouse and choose "Open with," "Automator Runner." If working properly, this should automatically sync the music from iTunes with your Sansa Fuze.
If that doesn't work, go into your iTunes library and highlight any DRM-protected tracks that you purchased from iTunes. Right-click and select "Make MP3 Version." These should now be compatible with the Automator.
This sounds like more or less of a "hack" than a solution, but this might be the only way to sync music from iTunes to your Fuze using Windows. If all else fails, make MP3 versions of the songs as shown above, then navigate to your iTunes folder where those files are stored. Then drag and drop these into Windows Media Player, where they should sync right onto your Fuze.
Hope that helps..
5answers
How do i download songs from my pc itunes to my iphone 4
There are 2 ways,
1) sync music to your iphone through itunes by selecting the music tab on itunes and select the song you want to sync
2) sync by manually dragging your music to the iphone icon in itunes. you will need to click off the box "manually sync files to iphone" at the bottom of itunes
1helpful
How do I get my itunes library to play on my sansaclipplus?
If you've purchased your music from the iTunes Store, it is in a format that is incompatible with your Clip. BUT, iTunes has the ability to convert songs to MP3 format, which your Clip can play. In iTunes, select a song(s), then under the "Advanced" pulldown menu, select "Create MP3 Version". Wait for it to finish, depending on how many songs you've selected, it could take some time.
Once you've created the MP3s, find them on disk and copy them to your Sansa Clip's "Music" folder. Or, use a program like iTunes Agent to sync an iTunes playlist directly to your Clip. Note, iTunes Agent requires a little bit of computer knowledge, it's not for pure novices.
http://ita.sourceforge.net/
How do I download music to my Sansa Clip MP3 Player
First, you have songs into your computer. Then, plug the device to computer and use one of two ways to download music to your Sansa Clip:
1. Select songs you want transfer, drag & drop them into Music folder in the device.
2. Use Windows Media Player: plug device to pc, open windows media player, click on Sync tab, drag and drop songs selected to Sync List space (on the right side of wmp), click on Start Sync button to transfer.
Good luck
How do I get the downloaded music from my computer into the clip?
You have 2 ways to transfer your songs from your computer to your sansa clip:
1. Plug sansa clip to computer, double click on "Sansa Clip ...GB", double click on "Internal Memory", you will see the file "Music", copy your songs and paste them into Music file of the device.
2. Using Windows Media Player: open windows media player, plug sansa clip into computer, click on Sync tab, select songs that you want to sync, drag and drop song selected into "Sync list" on the right side of the windows media player (you should update wmp11), then click on button Start Sync.
Good luck
3helpful
How do I download my Itunes onto the sansafuze?
First of all iTunes does not support any product that is not made by Apple, so you won't be able to sync your Sansa with iTunes. But there is another way, first you need to find out if the music in your iTunes library is the format, do this by right clicking several songs and clicking either "Properties" or "Get Info" or something like that. A window will pop up, look under "Kind," if it doesn't say MPEG audio file or MP3 then it needs to be converted to MP3 format. Now in iTunes(if your running windows) choose "File" and select "Preferences," now click "Import Settings" c64a1ba.png and under "Import to" select "MP3 Encoder." 41565a6.pngNow go to music and in the upper right corner of the iTunes window next to search, select the "List" view or click "View" and select "As List." 00e23ba.pngNow highlight all your songs by clicking the top song, holding shift down and hold down the page down arrow until all the songs are highlighted, now right click over the highlighted songs and click "Create MP3 Version" a59eab9.png
Now you just need to move all the songs to Windows Media Player or to any other Media Player that will work with your Player. Once this is done, plug your Sansa into your computer and open up your Media PLayer and sync it!I hope this helps!
WON'T BE ABLE TO SEE MUSIC FILES
The songs have to be in the right format. iTunes format is not compatible. If you do not buy a Rhapsody subscription and refresh the device through Rhapsody on the computer you initially synced it to, those songs will become useless as well over time. I would download songs in mp3 format only - whether paid or unpaid. They will never give you grief.
-Tha Mp3 Doctor
2answers
Using iTune cards for Sansa Clip MP3 Player
Sansa MP3 players will not play iTunes songs. Only iPods play iTune songs. Visit Limewire to download songs that you can play on your MP3 player.
Unable to download itunes from itunes library to sandisk clip mp3
Make sure the files are in MP3 or WMA file format. If they are in a different file format other than the ones above convert them because for audio those two are the file format that the sansa clip supports. Im not sure but iTunes convert songs to AAC or MP4 depending on the settings of it.
The best way to transfer songs tot he sansa clip is to change the mode of the player to MSC by going to Settings and then USB Mode. This would help detect the drive as a flash drive so you could copy and paste songs to it.
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
