Intel D845GLLY Motherboard Logo
Posted on Feb 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Istall the ram but do not desplay ram is out of socket and than buzzer 3 bip I was install Ram to other mother board Ram is ok please solve the problem
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 17, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
250
Points
For D845GLLY ,i tried with 512MB SDRAM(Duble side),it had booting problemwith long beep .i tried with each card of RAM seperately even then also i had same problem.
Mustang_Momm
Level 2:
  • Expert 86 Answers
  • Posted on Feb 15, 2010
Mustang_Momm
Expert
Level 2:
Answers
86
Questions
0
Helped
34345
Points
179
It is the wrong speed ram for the other motherboard for instance 133 sdram, 100 sd ram, pc2700 ddr ram, pc3200 ddr ram etc. you will have to see what type of ram is acceptable in your new board.
1 Related Answer
Anonymous
  • 2351 Answers
  • Posted on Apr 24, 2008
SOURCE: Intel 845 glly board please solve the problem
Hi Nadeem Nawaz,
No board will show display without memory. Your motherboard must run memory type;
Two DIMM sockets supporting 3.3 V (only) 168-pin 133 MHz Single Data Rate (SDR) SDRAM DIMMs with gold-plated contacts.
Unbuffered non-ECC DIMMs only.
Maximum total system memory: 2 GB; minimum total system memory: 64 MB.
Serial Presence Detect (SPD) DIMMs only.
Intel link showing memory specifications.
Intel Desktop Board D845GLLY
http://www.intel.com/support/motherboards/desktop/d845glly/sb/cs-012825.htm
If your memory is within Intel's memory specifications & you are not getting display on your monitor. It is possible that the integerated on board graphics (Shown on page 13 in your user manual), may be defective.
You can add a PCI video card to the PC. The Intel D845GLLY will auto detect the PCI video card. No need to enter the bios & make changes.
Please keep this in mind. The integrated video card is PCI, if it has failed, there is a good chance it will not see the PCI add in video card. If you can find a used (Working) PCI video card to test in the PC.
Intel Desktop Board D845GLLY main website link.
Luck!
1helpful
Bip long no start up
there maybe a problem with RAM, try to release the RAM, clean the pin with rubber if its dirty, then place it again in the socket. Bip long no start up can be sign that your RAM not correctly installed or its already damaged.
hope this useful, regard riyan.
2answers
Not gettin any signal from cpu
When the monitor shows no signal it means either the data cable going from the monitor to the computer or the computers graphics card needs to be replaced.
3answers
In My mother board continuous alarm sound is
Remove the Ram in Clean the Ram and Reinstall after do not stop the bip just in install another ram and check ..........ok
Hi sir i have an acer aspire 5101 which bips when i swtich it on and nothing shows on the screen.i have checked the ram an hard dive and they both ok
1st step you can check how many bips you hear, if continous bips , checks your vga by change with other if you sure that your ram and hd is ok, 2st if problem isn't solved ,remove all your card and clean all contact part all card with liquid cleaner, pci slot vga slot ram slot and processor socket after that you can try to assemble your card again , ok good try
4answers
Intel 845 chipset MB of Kobian make
try ramsticks individually (one at a time) in each of the memory banks until you get a post on the screen. if you don't get a post, then the memory might be parity and the board needs non-parity ***or vice versa***. Also, find the jumper on the motherboard for a bios reset, and reset the bios, then perform the previously stated memory tests.
3helpful
4answers
Intel d845 gvfn display problem.
sir i have a problemmy mother board intell d845 epi/d845gvsr my mother board is cannot desplayed or display is not come but if i remove rame the mother board is give error beaps if i attach ram board is not displayed
1helpful
2answers
Hi Nadeem Nawaz,
Luck!
2answers
Intel 845 chipset mother board no reaction - expecting solution
this is normal No-Ram. No-Beep.
The ram is all part of the bios analysis beep codes.
install memory, and setup the board to the manufacturers specification.
1 beep at post is normal on many bioses.
Mike @ compurepair.
Msi 478 socket mother board
to: pubudu,
you said that your ram is ok, but i think it's the ram which is your problem because of memory dumping with color blue. yes your ramis ok but the reason why not ok is because the latency is not compatible with your settings in bios
4helpful
6answers
Display problem in pentium mother board!
MODEL NO.--INTEL 845 GVRS. problem is --- power led is on but no display and no beep sound. SMBS, RAM ,, PROCESSER, & HD Are all ok. Pls. tell me how can i slove my problem?
Top Intel Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
