20 Most Recent ASUS P4BGL-MX 845GL (AS04P4BGL-MX) Motherboard Questions & Answers
try to reset bios first, u will see a baterry like a small coin
stop the computer an remove that baterry for 5 min
after put it back and start computer.
if is not working too try
if a firend got a video card(external) try to test it whit it
ASUS P4BGL-MX... | Answered on Sep 24, 2011
You can download the audio and device drivers from ASUS WEB site.Select your model motherboard/computer/laptop, and make sure you select driversthat matches your Windows operating system. Please click on this link to theirWEB support site : - http://support.asus.com/download/download.aspx?SLanguage=en-us
ASUS P4BGL-MX... | Answered on Sep 08, 2011
HI
you can update BIOS from BIOS updater.. BIOS updater is tool which is used to update bios on newer version...
try to download this tool from your motherboard manufacturer site..
caution:-
do not turn off your PC while updating your bios...
ifyou find this is helpful for you so please rate me this will encourage me to domore free work..
regards
sandy
ASUS P4BGL-MX... | Answered on Sep 06, 2011
Hi
No this Motherboard will only support up to Win XP.
ASUS P4BGL-MX... | Answered on Jul 20, 2011
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! red x right click select reinstall drivers if your computer came with a motherboard disc the drivers could be on it or you could download cnetdownload.com on the home page you should see the download software finder under that there will be a list platform, category sub category price from the category drop down list select drivers then from the price drop down list select free or which ever applies to your need
http://download.cnet.com/jetway-motherboard-driver/3000-2098_4-163033.html
hope this helps
ASUS P4BGL-MX... | Answered on Jun 24, 2011
download it here:
http://www.driverstock.com/ASUS-P4BGL-MX-driver-download/6-9-9995/index.html
ASUS P4BGL-MX... | Answered on May 05, 2011
i should have thank u, if u add some more details in ur query, anyway check the following :
1. check if ur power cable is properly connected and free from damage or broken
2. did u see any blinking indicators on ur front panel
3. open the cabinet and look if the fans are spining
4. did u hear any beeps during (POST) startup
***** if ur answer to the above is YES, then
remove all the power connectors (outside and inside) , all the add on cards, RAM sticks, (and also the processor if u have a pair of smart hand), carefully clean and blow out dusts, and reinsert all of them to thier respective places, and try again.
If u find all these solutions useless, ur processor or RAM or mainboard might defective.
ASUS P4BGL-MX... | Answered on Jan 27, 2011
Switch off the pc .
Remove cmos battery press on off switch for few seconds and install it again.
Please install another SMPS for cheeking.
Shibuda,
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
ASUS P4BGL-MX... | Answered on Jan 19, 2011
control panel,display,settings you can make adjustments for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general
dpi normal size,larger size or custom settings
hope this helps
ASUS P4BGL-MX... | Answered on Nov 17, 2010
you try to reset your bios at first u remove the cmos battery from motherboard after that you remove the jumper and ram and install it again. so i think your problems is resolve if still u getting same than you please revert back.................
ASUS P4BGL-MX... | Answered on Oct 08, 2010
Download the user manual from here
ASUS P4BGL-MX... | Answered on Apr 07, 2010
you can get bio from asus driver download read instrusion ok jim
ASUS P4BGL-MX... | Answered on Mar 24, 2010
board has getting on but desply not come and cpu surrounding componant not get power
ASUS P4BGL-MX... | Answered on Mar 11, 2010
Hi friend,
go to the below ASUS drivers side and download the appropriate drivers.
Thanks,
ASUS P4BGL-MX... | Answered on Feb 20, 2010
I read a solution of your problems, i did not ry this. But i want you to try in your motherboard: this was qoute by
" 9. anonobomber, 07-05-2002 09:51 read the manual from your motherboard, I'll quote it for you; Chassis Intrusion Lead (4-1 pin CHASSIS) This requires an external detection mechanism such as a chassis intrusion monitor/microswitch. The sensor is triggered when a high level signal is sent to the Chassis Signal Lead, which occurs when a panel or light detector is triggered. This function works with an optional ASUS CIDB chassis intrusion module (see your vendor for more details). If the chassis intrusion lead is not used, a jumper cap must be placed over the pins to close the circuit.
pinout 1[+5volt] [power supply standby] [chassis signal] [ground]
in order to supress the messages you are getting you will need to get a jumper to fit over the chassis signal and ground to bypass the chassis intrusion detection circuit.
This has nothing to do with resetting the CMOS. For board specific locations of the pins check http://www.asus.com.tw for the manual pertaining to your motherboard"
ASUS P4BGL-MX... | Answered on Feb 12, 2010
check asmps if not work put vj/ graphic card in mother bord to check.
ASUS P4BGL-MX... | Answered on Oct 31, 2009
Disconnect all devices from the power supply EXCEPT the motherboard
Remove any extra cards including video etc.(plug monitor into the onboard)
If you hear any beeps these can indictate where the fault is.
either of these sites below will help you further with that
Beep codes Pc
More beep codes
Power up the pc and see if the fans are working.
If not then double check the power connections to the board.
If you still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
ASUS P4BGL-MX... | Answered on Sep 29, 2009
ASUS P4BGL-MX 845GL (AS04P4BGL-MX) Motherboard Logo
58 questions posted
Popular Products
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • ASUS Computers & Internet
Most Popular Question
win xp driver asus asus p4bgl mx support
  • Computers & Internet
