Toshiba Satellite 5205-S503 Notebook Logo
Posted on Feb 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I want to restore my toshiba satellite 5205-s503 to factory settings. please help. i tried the whole pressing f8 repeatedly thing and there are no options to restore the computer to factory settings.
Anonymous
Level 3:
  • Master 415 Answers
  • Posted on Feb 12, 2010
Anonymous
Master
Level 3:
Answers
415
Questions
0
Helped
125055
Points
1200
You will need the restore cds that came with your laptop. Insert the restore cd in your dvd drive and restart your computer. When the message "Press any key to boot from cd" press enter.
Then follow the on screen instructions to restore your computer.
Regards,
nicolasiac
My satellite 5205-s503 wont turn on, the power light just blinks
Try plugging it into a different outlet. If that doesn't work, test your ac adapter. Check the voltage for 19.5v.
6helpful
HOW TO RESTORE FACTORY DEFAULT SETTING MY TOSHIBA SATELLITE L670D WINDOWS 7, KINDLY HELP ME, I TRY USING RECOVERY DISC BUT IT NOT WORK.
If my answer has helped you today please offer four thumbs up as thanks!
Take account of any files or programs you still want to use after the Toshiba laptop is restored back to its factory settings. Transfer the files to a backup location, such as a USB flash drive or external hard drive.
Restart the Toshiba Satellite laptop's operating system. Wait for the Toshiba logo to appear on the screen.
Press the key that brings up the hard drive disk utility menu. Depending on the specific model of your Toshiba Satellite laptop, the key will either be "0," "F1," or "F8."
Press "1" or click "Restore Original Factory Image." Click "Yes." Select "Next" to begin the restoration process.
Restart the Toshiba laptop computer when the restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
Transfer the backup copies of the data you saved earlier back to the Toshiba's hard drive. Re-install any programs you need, such as your software firewall or anti-virus tool.
I forget my bios password ineed to rest the passord to restore by defolt sittnig
There are four ways to reset the BIOS password you can read about here http://www.fixya.com/support/r7229632-reset_or_remove_bios_password
1helpful
Forget password bios toshiba satlite 5205
To reset the BIOS read the information from this link.
In case of your Toshiba Satellite laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
4helpful
My acer netbook screen is always dim even when it is plugged into the wall
adjust brightness settings on most acer laptops u hold the FN key and press one of ur arrow keys quite often the left and right for brightness up and down hope this helps
4helpful
3answers
Toshiba satellite 5005-S504 boots over and over and over non stop
It sounds like the hard drive is dying. I had a computer do the same thing and it turned out to be the hard drive. You should still be able to access the bios though. Try hittind either delete or F1 as soon as your toshiba screen appears.
Satellite 5205-s505 speakers aren't working, headphones OK.
Start- Control panel- Sounds and Audio Devices- In the device volume section click Advanced- Click Advanced again and check if In the other controls section 1 PC Spk mute is checked if so uncheck it If that does not work please let me know so I can help you further
Toshiba 5205-S503 Laptop- No power
- You may want to try to reseating all neccessary things on the system like optical drive,hdd,memory but before you do that disengage the power from the system like the ac and battery.
-If no..go try to remove the optical drive first and then turn the system on, then if the system boot without the optical drive shut it down and put back the optical drive and boot to bios and load the default setting and boot the system normally.
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
