For Harwa (also branded Logik) 54cm colour TV with remote RC-A07 showing blue screen with red lock in the corner, hold down "music" button on remote for 10 seconds to unlock.
I'm not clear on this. When does it show a blue screen? When you have it in HDTV mode?
A Blue Screen means it's not getting a signal (or the signal is very weak, resulting in more static than picture).
If it is a blue screen for HDTV, how are you sure the HDTV receiver is working?
If you can answer those questions for me, I should be able to track down the problem. I'm not sure which direction to go yet.
Element Electronics blue screen no signal Questions ... - Fixya
www.fixya.com > Forum > Tags > blue screen no signal
Blue screen with ''component 2'' in a box shows. Then it goes black.There is also a humming coming from the tv. I have unplugged everything from the tv, and ...
? 2:26
https://www.youtube.com/watch?v=2FnqRRcQzNs
Feb 17, 2010 - Uploaded by pacman552sd1
... is a vid im attaching to my email to custamer support to try and fix my bad tv. ... LG LCD TV REPAIR - NO PICTURESCREEN FIX REVIEW ...
There is no Blue screen disable option on the camera.
Since the blue screen caused by the video heads, try to clean it up by running a cleaning cassette.
The cleaning cassette helps only for minor clogs of the Drum(video heads)
To me itcsounds like ypu have a 1080p signal, 1080i is what it accepts. The 1080p signal will only show up on half the screen. Switch blue ray player to 720p or 1080i output.
Most of the new TV's display a blue screen when there's no signal for it to lock on.
Try unplugging it for about 5-10 minutes and see if that clears up the
problem. Why? Because they have microprocessors in 'em (computer chips)
and just as like with any other operatingsystem,
they can hang up or crash. This isn't an uncommon problem with today's
TV sets. Unplugging it for awhile resets the microprocessor (in other
words, it causes it to re-boot when you plugit in again).
it is not seeing a signal source.in the earlier days,"snow" would be evident but today the tuner signal lost results in a blue screen.check the cable signals and the cable box.
i would put cable from the wall directly into the set and see if there is a picture,and then check that it is not set to aux input with nothing connected
On some TV's the screen will go blue if there is not a strong, solid video signal present. This is to prevent the showing of very snowy or all snow channels, or garbled, mixed-up external video signals. This is normal. On some VCR's the video signal changes when the FF or REW search feature is used, and this could trigger the TV to go to blue screen. The only way around this if you can enter the TV's menu and turn off the blue screen feature.
